th350 shifting problems, It woun't engage 1st unless in low?????
Discussion in 'The Garage' started by weisel, Feb 20, 2004.
  1. weisel
    weisel 1/2 ton status
    Feb 22, 2001
    491
    Laveen, AZ
    th350 shifting problems, It woun\'t engage 1st unless in low?????
    I have a th350 tranny. It all of a sudden started acting funny. It works fine in reverse, but if I shift to drive, I can feel it engage, then slip and act like its in neutral. I thought it was low on fluid, but its not. I found out that if I pull the shifter down into "low 1", the tranny will engage first gear and hold. I then can accelerate and then shift into drive and the tranny shifts fine. That is until I slow down enough (2-3 mph) and it will slip and act like its in neutral again. But then I pull it down into low and I'm off and running. Whats going on? I checked the shifting linkage, and it is adjusted correctly. I have never heard of a tranny slipping in a gear, but when shifted to low, act fine. Can anyone shed some light on this for me?
  2. Z3PR
    Z3PR Banned
    Mar 30, 2002
    19,217
    Everywhere
    Re: th350 shifting problems, It woun\'t engage 1st unless in low?????
    Is the tranny fluid brown ??? Does it smell burnt ???
  3. Okiemuddog
    Okiemuddog 1/2 ton status
    Mar 3, 2003
    1,260
    Guthrie, Oklahoma
    Humm, sounds to me like the valve body has gone south, check the fluid color, red or brown?
  4. weisel
    Feb 22, 2001
    491
    Laveen, AZ
    still red, but a littl burnt smelling. Is the tranny trashed?
  5. Z3PR
    Z3PR Banned
    Mar 30, 2002
    19,217
    Everywhere
    Might be able to get away with just changing fluid and filter. While you have the pan off pull the valve body and check to see no valves are stuck. If that doesn't cure it, get it into a tranny shop befor you burn it up.
  6. weisel
    Feb 22, 2001
    491
    Laveen, AZ
    never pulled a valve body before, but am pritty confidant around the shop. Is it pritty strait forward?
  7. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    yea just dont lose any check balls. you don't need to pull the valve body unless there is a stuck valve. just stick a oring pick in there and see if you can move the valves easily.
  8. weisel
    Feb 22, 2001
    491
    Laveen, AZ
    do I need a gasket?
  9. big83chevy4x4
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    yea you will need the gaskets, and i can get them for you.
    email me and i will give you some prices big83chevy4x4@yahoo.com /forums/images/graemlins/deal.gif
