TH350 strengh
Discussion in 'The Garage' started by 82Scottsdale, Feb 19, 2007.
  1. 82Scottsdale
    82Scottsdale 1/2 ton status
    Jan 8, 2007
    133
    IL
    Ok i have a th350/205 behind a mild 350 im wonding how strong it is, i fried the pump in it before offroading and had to get it rebuild about 3,000miles ago but it had a hd b&m shift kit in it and i had another one put it upon rebuild so how strong is it and how long with it last me offroading?
    Tts in a 82 chevy scottsdale scsb with a dana 44 front and a 12 bolt rear both with 4:56 gears and a detroit locker in the rear on 39 by 18 micky thompsons.
  2. 74BBPowerHouse
    74BBPowerHouse Registered Member
    Mar 17, 2006
    90
    Mount Angel, OR
    I think with a 350 of any decent power youll be ok. they hold up great on BB's when your not running a ton of power.
  3. 82Scottsdale
    Jan 8, 2007
    133
    IL
    ok cause im scared to fry it again cause i dont have the cash to get it rebuilt again haha but yea i offroad a lot and was snow wheeling last night doing donuts and hitting big snow banks and stuff, so yea i was just worried about frying it like last time, well last time the gears in the pump grinded down and sent metal shavings though the whole tranny and it tore the front input seal and leaked tranny fluid all over so yea bad time for me well thanks for the help
  4. muddermilitia
    muddermilitia ThatTrazerGuy GMOTM Winner
    Nov 10, 2005
    5,742
    76
    NE Illinois
    I think you should be ok as long as you have a good trans cooler. By the way, where are you located in IL?
  5. jekbrown
    May 19, 2001
    45,029
    362
    Vancouver, WA, USA
    considering that th400s cost almost the exact same amount of $ to rebuild... I didn't see much reason to run a th350 when I decided to go to a 3 speed. TH400 has more beef and costs about the same... why take the weaker option?
    j
  6. BigEasy
    BigEasy 1/2 ton status
    Dec 18, 2006
    418
    U-jeen, Oragun
    With your set-up, I think I'd worry more about blowing the rearend instead of frying the transmission.
  7. 82Scottsdale
    Jan 8, 2007
    133
    IL
    haha yea im worried about my axle more then my tranny and i brake torqe it too, yea i have a HD B&M tranny cooler mounted up front but if i break my axle more of a reason to go a 14 bolt the local you pull it has some in there i could pull and muddermilitia i am located in Batavia,IL next to Aroura and Geneva and the Tri city area hbu? Jekbrown i couldnt go with a TH400 because there wasnt any around here and i would need a adapter and stuff to make it work with my 205 and my th350 rebuilt with the shift kit and new TC was around 300 give or take i dont remember but my dad paid for it cause im in HS with no job and have my own business on the side in car audio building boxes and what not
  8. darryl
    darryl Registered Member
    Jan 14, 2007
    33
    edmonton canada
    if a th350 is built properyl it will take the power of a built smallblock
    as the guys said use a cooler and keep the atf clean and consider a deep pan for oil volume
    the nonlock versions have slightly stronger inputs and if you have a lockup put a kill switch in the power feed so it will not lockup in 4lo
    lockup my stop heating but it also cuts lube flow
  9. 82Scottsdale
    Jan 8, 2007
    133
    IL
    yea its also got a B&M deeper pan with fins on it and the filter is lowered too with the cooler i should be good and its a non lock up,well thanks for the help now i dont ahve to worry about the tranny now only the axles lol
  10. 74BBPowerHouse
    Mar 17, 2006
    90
    Mount Angel, OR
    FYI Advanced Adapters does make an adapter for a 205 that was on a th350 for a th400. You need a 2wd th400. Like 650 bucks. But once i get it in ill be the only one i know of around here with that setup
