th350,th400,200r4,700r4 - np203,np205,np207,np208?
Discussion in 'The Garage' started by swamp donkey, Oct 17, 2002.
  1. swamp donkey
    swamp donkey 1/2 ton status
    Apr 29, 2002
    186
    Thousand Oaks, CA
    I'm sure everyone is sick of my auto tranny questions by now, but I have learned allot (and the more I learn the more I realize I don't know).
    Can someone break down the above tranny's/t-cases for me? I understand that the 350's and 400's are 3speed and the others are overdrive, but other than that... what should I know, and if I am converting my daily driver to auto from 4 speed, what combo do I want?
    As a side note, if the tranny I get does not have a torque converter which one should I get?
    Thanks a trillion billion.
  2. zakk
    zakk 1/2 ton status
    Sep 21, 2001
    4,762
    San Jose CA
    best cheap Auto combo: TH400 + NP205
    best expensive auto: Allison + 205 (not sure if it would work)
    Best manual: 465 + 205
  3. GMslave
    GMslave 1/2 ton status
    Oct 3, 2002
    113
    Flint, Michigan
    [/ QUOTE ] I'll assume you have a good reason for why you are converting, so here's my question "What do you want your truck to do?" What are you willing to live with? How much can you spend? (ok that's more than one question, oh well)
  4. swamp donkey
    Apr 29, 2002
    186
    Thousand Oaks, CA
    GMslave,
    Yeah I have a good reason to convert, I hate to shift. I live in Los Angeles, and with traffic the clutch is a killer.
    As far as my plans, maybe some sand dunes, other than that just a daily driver.
    As far as budget goes, I have squat. I am looking at buying a used combo, and hoping to get the whole thing and install it (minus shifter) for $500.
  5. GMslave
    Oct 3, 2002
    113
    Flint, Michigan
    IMO, you should look at a th 350 with either 203,205, or a 208. The 203's are heavy as HELL, so be warned. I just installed mine back into my truck by myself, big suckfest. You probably won't find a 350/205 combo for cheap but if you do grab it. Same with a 400/205. I ran a 350/208 combo in another project, which held up pretty good (2 years) but when it let go, it was beyond ugly. Besides, a 208 will need a different rear shaft (slip yoke). A TH700 will probably be out of your price range if you have to get it rebuilt, but it comes with a 3.04 (?) first gear, which is /forums/images/graemlins/thumb.gif off road. I run a 350/203, with a TCI 2000 stall converter. So far, I like it. It gets the revs going just enough before it really takes off, since I'll never go in the rocks, it works.My .02
  6. 84k5
    84k5 1/2 ton status
    May 13, 2000
    2,949
    Dublin, CA
    203=full time chain drive..most have been converted to part time though about 2:1 low
    205=part time gear drive about 2:1 low
    208=part time chain drive, aluminum housing, slip yoke,2.6:1 low
    the 400 is pretty much a beefier version of the 350
    the 700 has od, but is weaker. later versions (after 85 i think?) are better. what ever you get put a cooler on it. good luck.
  7. zakk
    zakk 1/2 ton status
    Sep 21, 2001
    4,762
    San Jose CA
    actually
    a 203 is 2.1:1
    a 205 is 1.96:1
    dunno what a 208 is, never even seen one /forums/images/graemlins/grin.gif
  8. thatK30guy
    Jan 12, 2001
    32,076
    55
    What about the 475 turbo tranny? Its the motorhome 400 tranny thats a lot stronger than the 400. /forums/images/graemlins/wink.gif
  9. BLUESMAN
    BLUESMAN 1/2 ton status
    Oct 3, 2001
    951
    Phoenix(but it\'s a dry heat...like an oven!)AZ.
    The most common trans/t-case you are going to find behind an K/5 will be the TH350/203.Not a bad combo.The driveshafts be sure and pick them up too,seems every other combo of trans/t-cases are different lengths.You should be able to pick up the trans/t-case and shafts for under $500.The other combo prob would be the TH350/208.The 208 is alum. and has an 2.62:1 lo-range(205 is 2.0:1).I agree with others on the TH700,the good ones are '88 and up and are costly to rebuild.Find someone to swap your manual for an auto set-up....you might actually make some $ on the deal.Good Luck!
  10. swamp donkey
    Apr 29, 2002
    186
    Thousand Oaks, CA
    I found a 350/203 combo mated together with torque converter. $200 for everything. The 203 has no 4-hi.
    Can I still use the 27 spline input (output?) shaft and adapter?
    What pitfalls am I looking at. I am picking up this tranny this weekend. If this costs me more than $500 (including a shifter) my wife will never let me work on the truck again - and I am only half joking.
  11. ol_grayfeather
    ol_grayfeather Registered Member
    Jan 15, 2001
    68
    Around Spokane, Washington
    NP 208 is 2.6:1 and with the 700r4 3.06:1 first gear you can get pretty low...for stock
    Dan
