TH350-TH400..will it fit??
Discussion in 'The Garage' started by NITRO, Feb 20, 2003.
  1. NITRO
    NITRO 1/2 ton status
    Jan 9, 2002
    1,057
    Frankfort In
    im goin from a th350 to a th400. the th350 is connected to a 203 right now. the th400 has the adapter with it from a 205. if i just get the th400-203 adapter wil everything else work? thanx
    NITRO
  2. zakk
    zakk 1/2 ton status
    Sep 21, 2001
    4,762
    San Jose CA
    no, the 400 is longer.
  3. outlaw612
    outlaw612 1/2 ton status
    Feb 11, 2001
    2,342
    Springfield, Illinois
    the th400 will have a different spline count also.
  4. NITRO
    Jan 9, 2002
    1,057
    Frankfort In
    well then my next question is how long do u think a th350 can take a 454??
    NITRO
  5. outlaw612
    Feb 11, 2001
    2,342
    Id say it depends on your driving style. If youre hard on it, you can break anything. Im gonna be running a stock 454 with a 700r4. The th350 should hold up if youre easy with the skinny pedal.
  6. Leadfoot
    Nov 28, 2000
    3,112
    Western Massachusetts
    Is the 350 bone stock? Keep in mind auto's are designed to fail (clutch material wears every shift). Even a good tranny will fail behind a 6 cylinder after enought shifts. A 454 will generally speed that process along (especially if the tranny is at the end of the line to begin with). Same with a manual clutch (except that doesn't require a tranny teardown). As with manual clutches, there are all different types and qualities of th350 internals. Good internals (clutches, steels, bands, and sprags) will live long behind a 454, and if you want to be stupid with the skinny pedal, they offer harder input/output shafts, sungears, reaction shells, etc. to make it last. There are mud trucks here that run blown BBC's and run 350's (most are manual valve bodies, but there are a few full autos).
  7. 70jimmy
    70jimmy 3/4 ton status Premium Member GMOTM Winner
    Mar 3, 2000
    5,962
    252
    Released from Pueblo, told I belong in Southpark
    Seems like when I had the 400 swapped into my 350 with a 203 they swapped output shaft, adapter, and clutches from the 350 into the 400. 400 was out of car and 350 tranny was from truck. Is this possible. I didnt do the work other than helping bolt it back in.
