Th350 To 700r Swap
Discussion in 'The Garage' started by 72jimmycst, Oct 29, 2005.
  1. 72jimmycst
    72jimmycst Registered Member
    Sep 5, 2005
    17
    Rapid City SD
    I would like to swap my TH350 for a 700R out of an 88 burb. Will the 700 bolt on to a NP205 or is there something else i need. How about mounts. Does anyone whose done this have any advice?
  2. Chaddy
    Chaddy 1/2 ton status GMOTM Winner
    May 23, 2005
    4,110
    Salt Lake City,Utah
    you will need an adapter plate and a new mount, drive lines and possibly exaust
  3. bdozeraz
    bdozeraz 1/2 ton status
    Nov 8, 2004
    212
    Phx, Az
    the easiest way is get the short adapter shaft for the 700r4 from advanced adapters. Have it installed in the trans then the back of the 700r4 is the same as the th350. Move the crossmember back 2 inches, lengthen the front shaft, shorten the rear shaft and your done. You have to use 1310 cv joint on the front shaft to clear the trans pan. If you want bigger ujoints use the stock 4x4 output shaft on the 700r4 and get the spacer adapter to go between it and the 205. It makes the drivetrain 2 or 3 inches longer and gives a little more room for the cv joint in the front shaft.
    Brent
