TH350 to a TH400....
Discussion in 'The Garage' started by NITRO, Mar 1, 2003.
  1. NITRO
    NITRO 1/2 ton status
    Jan 9, 2002
    1,057
    Frankfort In
    i have a 79 K5 that has a 454 goin in next weekend. so im thinkin bout swappin trannies. but i wanna make sure first. the th400 has the 205 adapter and all of that stuff and will bolt up to the np203 if i just re-drill and tap new threads in the x-case right? it is MUDZER's in the for sale section. also, is it the same length? i dont really wanna hafta do new Driveshafts and drill new holes for the x-member. thanx a lot
    NITRO
  2. 77fixer
    77fixer 1/2 ton status
    Nov 22, 2001
    464
    Meridian, ID 83646
    I won't be the same length. A TH400 is longer than a 350 and the 400/205 adapter is like 4-4.5" long, where the 350/203 adapter is only about an inch thick.
    Brett /forums/images/graemlins/burb.gif /forums/images/graemlins/k5.gif
  3. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    The Turbo 400 is longer than the Turbo 350. It also has a 32 spline output shaft, while your Turbo 350 has a 27 spline output shaft. /forums/images/graemlins/frown.gif
  4. bad_bo_ti
    bad_bo_ti 1/2 ton status
    1,027
    OhiO
    can the output shafts be switched from the 350 to the 400? not trying to hi jack a post just was curious as i am thinking of getting a 400 and if i cant find a 4wd one then i could look for a 2wd one and switch the out put shaft from my 350 to it if it will work.. thanks chris
  5. HarryH3
    May 31, 2000
    10,384
    Georgetown, TX
    I dont' think so. /forums/images/graemlins/frown.gif
  6. NITRO
    Jan 9, 2002
    1,057
    Frankfort In
    its aight...u arent hijackin it. it is in the for sale forum and mudzer says it is made to bolt up to a np203 he just doesnt have the right adapter
    /forums/images/graemlins/confused.gif /forums/images/graemlins/confused.gif
    NITRO
