th350 to sm465 conversion....
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Waxer, May 14, 2001.
  1. Waxer
    Waxer 1/2 ton status Author
    1,857
    Long Beach, CA.
    I'm currently doing this conversion and swapped all the parts with Blazer91 (Mike) and we didnt have to swap steering columns as he already had the auto column in his wifes K5. My question is, to disable the nuetral safety switch in the column, do I just tear her down to the nuetral safety switch and take it out of the equation by attaching the two wires together permanently? any help would be appreciated.
  2. dyeager535
    26,977
    Someone had already done that on mine, so yes, you can. I believe ones a large purple wire and the other is...?
    Just make sure that the connection is solid and not exposed when you are done and you are all set. Then you can drive around in 4low with the starter :)
    Dorian
    My tech/links page: <A target="_blank" HREF=http://www.dorianyeager.com/index2.html>http://www.dorianyeager.com/index2.html</A>
    No anti-theft measures on your truck? No pity when its stolen
  3. Bigd
    Bigd 1/2 ton status
    Apr 3, 2000
    399
    Co,Colorado Springs
    I believe the two wires are purple.Cut the wires then run it too a hidden switch.Turn switch on too let it start when you want turn off too not.It's not much but it might help against the current rash of stolen blazers.
  4. Waxer
    1,857
    Long Beach, CA.
    Thats a good idea. I already have a kill switch for the distributor but one to the ignition couldnt hurt. :)
  5. Grim-Reaper
    7,385
    Atlanta
    Put the colum in park and drive the pin that holds the shifter on out and your done [​IMG]
    Diging it in the dirt with my K5's
    Grim-Reaper
    <A target="_blank" HREF=http://grimsk5s.coloradok5.com/>http://grimsk5s.coloradok5.com/</A>
  6. californiak5
    californiak5 1/2 ton status
    Oct 25, 2000
    820
    Oceanside, Ca. 92056
    Hey Steven,
    Are you going to do a right up on this conversion. It sure would be nice to see all that goes into it, as far as pedals, cutting holes in the floor for the shifter and all the technical stuff. Just a thought.
    See Ya,
    Keith
    [​IMG] <font color=green>Born to Drive My K5</font color=green> [​IMG]
  7. Waxer
    1,857
    Long Beach, CA.
    I can....it wouldnt be a problem
    Matter of fact, thats a good idea.
    Grim: reason I'm asking about bypassing the Nuetra Safety Switch is that mine is messed up anyways, sometimes I cant start my truck until I shift the lever a few hundred times..
  8. blazen91
    blazen91 1/2 ton status
    Sep 10, 2000
    1,738
    Hesperia, Ca 92345
    Steven- Tracy is going to bring out the parts to you this week end. Thanks for the trade!!
    <A target="_blank" HREF=http://www.blazen91.coloradok5.com>http://www.blazen91.coloradok5.com</A>
    Protect the land FOR the people
    Not FROM the people
  9. Waxer
    1,857
    Long Beach, CA.
    Mike, Thanks for getting back to me so soon. That will work out great with Tracy dropping off the rest of the parts.
