TH350 to TH400 swap
Discussion in 'The Garage' started by Klef72K5, Mar 2, 2005.
  1. Klef72K5
    Klef72K5 1/2 ton status
    Apr 8, 2001
    249
    Columbia City, Indiana
    Is the distance from the bell housing to the crossmember mount the same between the 350 and 400? All I have is the 350 crossmember and I'm wanting to mount the 400 to it and bolt it to the frame. What about depth, does a 400 crossmember drop down more? I can alway put spaceres in if so.
  2. teamgerth
    teamgerth Registered Member
    Sep 1, 2003
    57
    Hubbard, OR
    your cross member should work, but the th-400 is about 3" longer than the th-350 and the transfer case and adapter are also different if the th-400 doesn't already have a transfer on it.
  3. sweetk30
    Nov 1, 2004
    25,548
    543
    horseheads , ny 14845
    the tranny fill tube also with the kick down bracket and switch for the gas pedel also . and there is short pan and deep pan tranny pans.
