TH350 tranny fluid capacity (w/ converter)
Discussion in 'The Garage' started by mr_clean, Sep 2, 2005.
  1. mr_clean
    mr_clean 1/2 ton status
    Sep 21, 2003
    348
    Sacramento, CA
    I need to know how much fluid the converter holds. I know the tranny is supposed to be between 5 - 6 pints (at least that is what the couple books I have say) but if the converter, stock cooler and lines were all drained, how much more does that take?
    If I turn it over without starting it will that pump fluid through the system?
    Also will it be low enough that damage will occure if I start it with only adding the 5 pints to the tranny and leaving it in park while I check the tranny fluid level.
    Thanks,
    Scott
  2. sweetk30
    Nov 1, 2004
    25,547
    542
    horseheads , ny 14845
    get 1 case of fluid. then add 4 quarts. fire up and add as needed to get to level. 10-11 qrt stock convertor 12-13 for hd convertor.
  3. mr_clean
    Sep 21, 2003
    348
    Sacramento, CA
    Perfect, thanks!
  4. sweetk30
    Nov 1, 2004
    25,547
    542
    filler er up and good luck:D
  5. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    Yep, it's WAY more than a few pints. When I installed my Turbo 400 after we had totally drained everything, it took 14 quarts. :eek1: The 4WD Turbo 400's have an extra deep pan and an extension on the pickup tube, so they hold 3 or 4 quarts more than a car version. It helps keep fluid going to the trans on odd angles. The 4WD Turbo 350's might have the same setup.
