Th350 Trouble
Discussion in 'The Garage' started by ron_mac01, Sep 26, 2005.
  1. ron_mac01
    ron_mac01 Registered Member
    Sep 26, 2005
    17
    ATL,GA
    I have a TH350 trans after warming up on launch in the morning it catches
    normally. After I have driven it a while and say I stop at a stop sign or
    red light the launch off seems to slip or not catch right off what problems does anybody think I have??????????????????????
  2. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    have you checked your fluid level properly? Sounds like maybe not enough line pressure from running the pump low on fluid. Just a thought of many...
  3. ron_mac01
    Sep 26, 2005
    17
    ATL,GA
    YES I CHECKED THE FLUID LEVEL AND IT IS OK SO YOU ARE SAYING THE PUMP PRESSURE IS NOT HIGH ENOUGH (I INSTALLED A TRANSMISSION COOLER FROM THE LOCAL AUTO PART STORE ) DO YOU THINK I SHOULD CONNECT IT DIRECTLY TO THE RADIATOR ? :confused: (I DONT THINK THAT MAKE ANY DIFFERENCE BUT I COULD TRY. ONE MORE THING IF THERE IS NOT ENOUGH TRANNY FLUID PUT IN THE TORQUE CONVERTOR WHEN INSALLING COULD THAT CAUSE THAT PROBLEM
  4. ak bandit
    ak bandit 1/2 ton status
    Sep 10, 2004
    386
    Eagle River, Alaska
    Your torque converter gets it's fluid from the transmission. Some guys install their torque converters with NO fluid at all. So if your tranny is full of fluid, no the TC fluid wouldnt be an issue.
  5. danny7139
    danny7139 1/2 ton status
    Jan 27, 2005
    227
    florida
    Sounds Like Its The Pressure I Like It Better To Be Directly Connected To The Radiator :D
  6. stayaway
    stayaway Registered Member
    Aug 1, 2005
    59
    georgia
    I had a 350 that was kinda doing same thing serviced it and all was good
