TH350 Vacuum HELP
Discussion in 'The Garage' started by bouncytruck, Aug 20, 2003.
  1. bouncytruck
    bouncytruck 1/2 ton status
    Oct 11, 2001
    858
    Bothell, WA
    HELP I rebuilt my TH350 at the end of last summer and it never shifted into 3rd properly. Last night was the first time I've had a chance to really test it out (we had a baby in January). It appears to be shifting into third if I'm not giving it any gas. When I step on the gas it shifts down to 2nd and won't shift up again until I start coasting again. I think it might be a vacuum line issue. right now, the vacuum line to the tranny is going to a port in the Edelbrock Performer intake manifold - the same one as the power brake vacuum. I switched it there because someone told me that is where it should be hooked up. Before the rebuild, it was attached to the carb (quadrajet). Where should the vacuum lines all be hooked up? I don't have a vacuum gauge. I really want to drive my truck again before the weather turns to rain
  2. Larry_in_Tx
    Larry_in_Tx 1/2 ton status
    Oct 24, 2002
    404
    Houston Tx.
    On mine the power brake comes off the carb and the tranny comes off the tree on the manifold.
    I could guess why it might act up if the where both coming out of the intake but I can’t say for sure...I’m half monkeyfied when I work on my truck and I just put the lines back where they where on the 350 when I did the engine swap.
    I’m sure someone can help out more.
  3. bouncytruck
    Oct 11, 2001
    858
    Bothell, WA
    which postion on the carb is it hooked into? My vacuum advance for the disty & PCV on the are hooked into the carb. I capped off one of the ports.
  4. dyeager535
    26,979
    It needs full manifold vacuum, which is what you have it hooked up to.
    Could be a vacuum modulator issue I guess, have you checked that its working correctly?
  5. bouncytruck
    Oct 11, 2001
    858
    Bothell, WA
    The vacuum modulator is brand new (came with the rebuild kit). It appears to be working because last night I adjusted the shift point earlier. Is it a problem having a "T" in the vacuum line and having it go to both the power breaks and the transmission vacuum modulator?
  6. diesel4me
    Jul 24, 2003
    17,546
    937
    Massachussetts
    I dont think it matters too much where you get the vacuum from,as long as its manifold vacuum and not "ported"vacuum(above the throttle plates in the carb)you can check that with the engine running,ported vacuum has no suction at idle,only when accelerating and throttle is open--if you reverse the hoses it may act like you described--but it sounds to me that tour detent downshift cable is adjusted too tight and is pulling the tranny back into second gear(or passing gear)too soon--make sure its adjusted properly. /forums/images/graemlins/grin.gifAlso-its not a good idea to hook up your pcv and power brakes together unless you have the little charcoal canister thing (looks like inline gas filter)hooked up inbetween the 2,because the blowby vapors can ruin the diagphram in the brake booster after awhile!~ /forums/images/graemlins/frown.gif
  7. bouncytruck
    Oct 11, 2001
    858
    Bothell, WA
    Thanks, I was think the same issue with the detent cable so I disconnected it. Still the same issue. The PCV is hooked into one of the ports in the carb. The brakes and the transmission modulator are hooked up to the intake manifold with a plastic "T" from NAPA.
  8. dyeager535
    26,979
    Shouldn't really be a problem, don't usually hit the brakes while you are trying to upshift. /forums/images/graemlins/smile.gif
    If it's new, you can't always be sure it's working correctly, but if it wasn't full of fluid when you pulled the line off, it's probably good.
  9. Calclips
    Calclips 1/2 ton status
    Apr 4, 2001
    1,005
    Swartz Creek, Michigan/Flint while in school
    Yeah, dorian is correct. If you pull the vacuum line off the modulator and tranny fluid comes out, its bad... if not... its good. At least thats what I was told.
  10. bouncytruck
    Oct 11, 2001
    858
    Bothell, WA
    No fluid came out when I pulled the vacuum line off the modulator.
  11. Beast388
    Beast388 1/2 ton status
    Nov 6, 2001
    3,039
    Clinton, IA USA
    FWIW, my modulator and power brakes are T'd together and hooked to manifold vacuum as well and it shifts just fine. I rebuilt my TH350 myself too. /forums/images/graemlins/thumb.gif
    If you are having a lack of vacuum for the modulator problem, it would act the same for the 1-2 and 2-3 shifts, not just 2-3.
  12. mudhog
    Nov 6, 2000
    17,899
    portland oregon
    it could be a stuck valve in the valve body or you could have pinched or broken a seal internally when putting it together /forums/images/graemlins/eek.gif
