TH350 vent through dipstick??
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by elkboy, Jul 1, 2001.
  1. elkboy
    elkboy 1/2 ton status
    Aug 18, 2000
    293
    Hillsboro Oregon
    Does any one know where the vent in located on a pre 80 TH350? I think it may be vented through the dipstick but I'm not sure. Since I put a water proof dipstick in I have some trans fluid leaking into the transfer case. Am I a dipstick, or do I need a new one [​IMG].
    <font color=red> Elkboy </font color=red> 82 K5 fuel injected H.O.305, TH350/205, 14bolt/10bolt and 39.5 TSL's.
  2. outlaw612
    outlaw612 1/2 ton status
    Feb 11, 2001
    2,342
    Springfield, Illinois
    Im not positve, but I think the vent is on the top on the passenger side.
  3. Wheels
    Wheels 1/2 ton status
    Aug 18, 2000
    638
    Check the case vent, it is on the top side of the tranny right along the seam. Can't remember if it vents to the drivers or passengers side. Going to the water tight dipstick probably cut off the the escape passage if the actual vent is blocked. This will cause the fluid to blow by the seals and end up in either the t-case or out by the convertor.
  4. RaisedK5
    RaisedK5 1/2 ton status
    932
    Long Beach, CA
    I'm visualizing as i type, i believe it vents to the driverside above the shifter linkage, way up on top, they're usually plastic and i melted the one on my t-case, maybe it got a little too hot and melted shut, should just be pushed into the hole reach up and see if you find it, it should be there.
    RaisedK5
    "Of all the things I've lost, I think I miss my mind the most!"
  5. Goose
    Goose 1/2 ton status
    1,127
    South Central Kansas
    I had a '77 K10 with a TH350. It was on the top, almost center about where the case flares to goto the block. It was a steel tube about an inch long.
  6. elkboy
    Aug 18, 2000
    293
    Hillsboro Oregon
    Thanks, I'll feel around and see if I can find it and get it unplugged.
