Th350?
Discussion in 'The Garage' started by justwhatido, Mar 29, 2005.
  1. justwhatido
    justwhatido 1/2 ton status
    Apr 8, 2004
    1,037
    Mobile, AL
    Pulled Engine, found the bellhousing cracked. Replace the case, buy a rebuilt transmission? Local transmission shop (Steve's Offroad uses him exclusively) will charge $65 to look at it, approx $250 to replace the case. Will not give a rebuild quote till they look at it.
    Suggested that I leave the 203 transfer case attached and the same $65 will get it checked out too?
    OK guys, good deal or not? Where to look and how much to pay for a good rebuilt (daily driver) tranny and 203?
    Fred
  2. Silver84k5
    Silver84k5 1/2 ton status
    Feb 7, 2002
    3,769
    Hillsboro Oregon
    i had my trans rebuilt and hopped up a little bit, with Some HD internal parts that i cant remember the name of. for around 400 bucks. i think it was a little less then 400, was a couple years ago....
  3. k20
    k20 3/4 ton status
    Sep 9, 2001
    5,068
    Mineral Springs, NC
    $250 for a case?!?! HD th400 cases sell for 75-125 here........and the guy I take mine to charges $325 to rebuild em, using your case. When I took him my tranny last time.....the only reusable parts were the case & the output shaft, still $325.
  4. 75-K5
    75-K5 3/4 ton status
    Apr 28, 2002
    5,353
    Anderson, Indiana
    Just find a blown tranny at a junkyard or similar place and have them swap the guts over. They must be selling gold cases. :crazy:
  5. justwhatido
    Apr 8, 2004
    1,037
    Mobile, AL
    clarification
    The $250 includes te original $65, the case, and installing the guts into the new case.
    Fred
  6. 75-K5
    Apr 28, 2002
    5,353
    Anderson, Indiana
    That's not a bad price then.
  7. k20
    k20 3/4 ton status
    Sep 9, 2001
    5,068
    Mineral Springs, NC
    does that 250 include new parts, or is it just tossing all the old stuff over? It wont turn into one of those, yeh itll be $450.......yeh we hadta swap out all the clutches, steels, bands......yadda yadda.....
  8. justwhatido
    Apr 8, 2004
    1,037
    Mobile, AL
    The $250 is just evaluating a nd swapping
    A rebuild will be additional. But here again, it's not a few hund on top of the $250. It will replace the $250 and the $65.
    After looking at waranteed replacements on line, it looks to be a better deal than I thought at first.
    Thanks guys, pics to follow after the engine build starts (tomorrow?)
    Fred
  9. sweetk30
    Nov 1, 2004
    25,552
    547
    horseheads , ny 14845
    post some pics of the damage. then we can tell you if it can be repaired by a pro. lots of cases are fixed for trail and street use.
  10. 1979jimmy350
    1979jimmy350 1/2 ton status
    Mar 24, 2004
    3,069
    Ann Arbor Mi
    you should look in to just replacing the bellhousing. Summit sells a replacment bell housing for the 350 tranny which is stronger than stock
  11. justwhatido
    Apr 8, 2004
    1,037
    Mobile, AL
    bellhousing
    seems to be all one piece with case in this case.
  12. 1979jimmy350
    Mar 24, 2004
    3,069
    Ann Arbor Mi
    yea the 350's are a one piece case but you cut off the old bell and put on the new one with bolts. Do a search i rember some body did it before on a 350
