th350
Discussion in 'The Garage' started by sunnyc123abc, Dec 17, 2006.
  1. sunnyc123abc
    sunnyc123abc 1/2 ton status
    Mar 12, 2005
    636
    SoCal
    So if i can't get my 700r4 fixed in time for my big bear trip, im thinking about putting my th350 in. I was just wondering wat rpms do you guys see on the highway, and gas milage. Also, i heard that i should use a steel vacuum line instead of rubber. any reason for this.
  2. diesel4me
    Jul 24, 2003
    17,561
    942
    Massachussetts
    a few..
    They use steel line for the modulator for a few reasons..one is rubber can collapse under vacuum ,or get pinched,and block the vacuum from getting to the modulator..also if the modulator diaphram leaked it would coat the inside of the hose with ATF and make it swell or mushy..rubber hose might burn on hot exhaust pipes too..:crazy:
  3. sunnyc123abc
    Mar 12, 2005
    636
    SoCal
    ok..i see now thanks
