th400/203 combo
Discussion in 'The Garage' started by 84CUCV, Apr 26, 2005.
  1. 84CUCV
    84CUCV 3/4 ton status Premium Member
    Jul 1, 2002
    7,115
    NJ for now
    I just got a good working 400 and 203. This is the set that is used for a ORD doubler right? I have a 205 of a sm465. What else do I need to make this work?
    thx mike
  2. nvrenuf
    Jan 7, 2002
    13,085
    251
    Mobile, Al.
    You'll need a 32 spline input for the 205, the actual Doubler kit and shifters.
  3. 84CUCV
    Jul 1, 2002
    7,115
    NJ for now
    OK so i dont have the right 205. damn thanks
  4. clarkjw24
    clarkjw24 1/2 ton status GMOTM Winner
    Dec 4, 2003
    3,531
    McBee, SC 29101
    The 205 is fine you just need the correct input shaft. ORD sells them and you can swap it in. :xmas:
  5. beater74
    beater74 1/2 ton status
    May 29, 2001
    1,749
    atlanta
    you will have to machine the 205 to handle the larger input bearing that the 32 spline input use's
  6. nvrenuf
    Jan 7, 2002
    13,085
    251
    Mobile, Al.
    There is a bearing available that will allow you to do the input shaft swap without machining the case.
  7. 84CUCV
    Jul 1, 2002
    7,115
    NJ for now
    Cool thanks guys mike
  8. clarkjw24
    Dec 4, 2003
    3,531
    McBee, SC 29101
    Someone said that its #6001 for the bearing.
  9. beater74
    May 29, 2001
    1,749
    atlanta
    really i've never heard that but now i know
