th400/205 questions
Discussion in 'The Garage' started by 90BCk5, Apr 19, 2005.
  1. 90BCk5
    90BCk5 1/2 ton status
    Apr 8, 2005
    278
    British Columbia
    just picked up a 400/205 combo with a B&M stage 2 shift kit and B&M 2500 rpm stall torque converter..... ive got a coupla questions that ive been wondering about, first off anyone know if i can order a full twin stick kit for the 205 with modified rails and levers? if so,where at and is it worth it?
    second question..... when everything is bolted up itll be 350/400/205
    F d60w/4.56 and R14bFF w/4.56 detroit
    should i chnge the lockup torque converter to higher/lower to use with this setup or chould i look at my engine to awnser this question?
    thanks
  2. atho
    atho 1/2 ton status
    May 14, 2003
    1,115
    Wayne County, Ohio
    About the twin stick, I have heard that you can take your 205 apart and send the shift rails to ORD, and they will properly machine them for you. They also sell a twin stick kit.
  3. Stephen
    Sep 15, 2000
    4,228
    144
    Carbondale Colorado
    Yup we can do it, no problem. You should probably call for more info on it or check in on our vendor page...
  4. 90BCk5
    Apr 8, 2005
    278
    British Columbia
    mmmmmm...twin stick
    thanks for the input on the np205!!
    can anyone help me out with the torque converter prob? that would be awesome!
  5. Eric M.
    Eric M. 1/2 ton status
    Dec 10, 2001
    2,118
    Oakland, CA
    I'm thinkin' you'd want a lower stall converter for wheelin'. Anyone else?
    Eric M.
  6. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    Depends on the kind of wheeling, tires size, motor, and final gear ratio. If you dont have deep gearing and have tall tires you don't want a super low stall converter unless you got a stout motor. It has alot of variables.
    Harley
  7. 90BCk5
    Apr 8, 2005
    278
    British Columbia
    k,maybe this will help, a 350 pushing about 300horse, 4.56 gears, and 37' mtr's and all around wheeling, hill climbs, mud, a bit of rock, lots of trail....
  8. steve_kibbe
    steve_kibbe 1/2 ton status
    Feb 4, 2004
    2,895
    Spartanburg, SC
    I would suggest a lower stall converter given your information. Either a stock stall or maybe 1500 stall. Personally I would go stock, your tranny temps will also be affected if you have a higher stall......more slipping means more heat buildup :o
