TH400 208 to 205 swap Qs
Discussion in 'The Garage' started by Swanson52, Aug 14, 2002.
  1. Swanson52
    Swanson52 1/2 ton status
    Mar 27, 2002
    2,586
    Centennial, CO
    What parts/modifications are needed to swap a (465 version) 205 to a TH400 that came with a 208? Thanks.
  2. Mr.Chevy4x4
    Mr.Chevy4x4 1/2 ton status
    Jun 16, 2000
    1,932
    Sims, NC
    You will need a 400/205 adapter, and you will need to convert your 205 to the 32 spline input which requires machining the case for a larger input bearing. Stephen Watson at ORD sells the parts you need to convert the 205. Good luck finding a good used 400/205 adapter.
    Mike
  3. Swanson52
    Mar 27, 2002
    2,586
    Centennial, CO
    Still available from GM?
  4. Mr.Chevy4x4
    Jun 16, 2000
    1,932
    Sims, NC
    Yes, but you probably don't want to pay the price for a new one!
    You might want to check with Wes(ThatK30Guy), he might have one he would part with.
    Mike
  5. Swanson52
    Mar 27, 2002
    2,586
    Centennial, CO
    Thank ya, thank ya very much.
  6. trukman1
    trukman1 1/2 ton status
    Mar 5, 2002
    129
    Ohio
    Try www.4xHeaven.com in NY. They have great prices and service is terrific. Can't say enough good about them! Gary
  7. wayne
    wayne 3/4 ton status
    Feb 1, 2001
    6,178
    Carlisle, Pa
    I might not be totally correct but as far as I know if you use a newer 205 with the round bolt pattern it will bolt right on using the 208 adapter. That might be another option for you.
  8. thatK30guy
    Jan 12, 2001
    32,076
    55
    What Wayne said.....
    You can use any 205 from '85 to '91 to fit right up to the 400 as long as the 400 had a 208 behind it.
    400/208 have the same length tailshaft on the 400 as do the '85 and newer 400/205 combos.
    If you still want to use the '84 and older 205's, you will need either the original 400 tranny or swap the tailshaft out.
  9. Swanson52
    Mar 27, 2002
    2,586
    Centennial, CO
    The 400 is an 85, and the 205 is a 79. I am to understand I need to swap the tailshaft on the 400, get the different input shaft for the 205 (plus machining), and get the 400/205 adapter?
  10. thatK30guy
    Jan 12, 2001
    32,076
    55
    OR.....
    You can simply trade your '79 205 for an '86 205 I have here at home.
    I'm in central Kansas, so you are just above me, but what town?
  11. thatK30guy
    Jan 12, 2001
    32,076
    55
    Another option for you if you want to use your '79 205:
    find any 2wd car or truck 400 tranny with a short tailshaft. By the time you take off the tailshaft housing, the shaft is the perfect length to fit in front of your 205. /forums/images/icons/wink.gif
  12. Swanson52
    Mar 27, 2002
    2,586
    Centennial, CO
    Trying to find a 400 around here (either 2wd or 4wd) is next to impossible. And the people that have em want your firstborn child in trade. You'd do the early 205/later 205 swap? You are not that far away from me...maybe I could pick up a K30/M1008 while I was there (my mom lives about 3 hours from you...I could pass of a parts run as a family visit). /forums/images/icons/grin.gif
  13. thatK30guy
    Jan 12, 2001
    32,076
    55
    I could do a trade with you as long as your '79 205 is the 32 spline t-case. I've been looking for one to use for a Doubler in the future. The '86 205 I have was gonna go into one of the trucks, but with my '85 needing a motor, I may as well get rid of everything. /forums/images/icons/frown.gif
    If you are interested in one of the trucks, let me know and I will send more pics and info about them. Both trucks are very good condition.
    Oh, BTW, do you have the adaptor for the 205? I have one on the 205 I have and its the 6 bolt round pattern to fit the 400.
  14. Swanson52
    Mar 27, 2002
    2,586
    Centennial, CO
    I have yet to pull the transmission and t-case apart, so everything is still there from the bellhousing to the output shaft yoke. I will tear them apart and check it out. I may be interested in your rigs. Can you PM with the details on both?
  15. Swanson52
    Mar 27, 2002
    2,586
    Centennial, CO
    These suckas replied to me today with a price on the 400/205 adapter....sitting down??? 300 bucks. /forums/images/icons/shocked.gif
  16. thatK30guy
    Jan 12, 2001
    32,076
    55
    Nope. You can get them brand new from gmpartsdirect.com by typing in part number #14022218 and the price will be just under or right at $200. /forums/images/icons/wink.gif
    BTW, this adaptor part number fits the '77 - '84 np205's bolted to a th400 tranny. /forums/images/icons/wink.gif
