th400/208
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by bushmaster, Mar 26, 2004.
  1. bushmaster
    bushmaster 1/2 ton status
    Jun 1, 2003
    146
    ct
    will a 208 from a 400 hook up with a 700r4?
  2. OL14BLAZ
    OL14BLAZ 1/2 ton status
    Aug 14, 2002
    1,815
    TEXAS, USA
    Nope, the spline count is different on the two. The one from the 400 is 32spline and the one from the 700 is going to be 27spline IIRC. /forums/images/graemlins/smirk.gif
    Eric
  3. BlazerGuy
    BlazerGuy 3/4 ton status
    Apr 20, 2000
    9,206
    abcde
    Yep a 208 for a TH700 has a 27 spline input...
  4. bablazer73
    bablazer73 1/2 ton status
    Apr 4, 2000
    3,363
    upstate ny
    But those cases come apart easy. If you need to, you can change the input shaft easy enough. We had to do that with my buddies plow truck this winter. He has a th350(same 27 spline) And The only case i had laying around was a 400/208. an hour to split the case and change input shaft and away we plowed.
  5. Mastiff
    Mastiff 1/2 ton status Premium Member
    Jul 21, 2002
    2,755
    48
    Tucson, AZ
    Not what you asked exactly, but my 208 from a 700 is now hooked up to a 400 through an adapter from Advance Adapters. Seems like they'd have something to go the other way too.
