Th400/208
Discussion in 'The Garage' started by 74BBPowerHouse, Apr 3, 2006.
  1. 74BBPowerHouse
    74BBPowerHouse Registered Member
    Mar 17, 2006
    90
    Mount Angel, OR
    How much messing around would I have to do to convert a Th400 with a 208 and change it to a 205?
  2. u2slow
    u2slow 1/2 ton status
    May 9, 2001
    2,217
    BC Canada
    Pretty easy... so long as you use a 85-90 style NP205 & adapter from a TH400 its a direct bolt up.
  3. Ronnie4wd
    Ronnie4wd 1/2 ton status GMOTM Winner
    Jun 4, 2002
    749
    Stockholm.Sweden
    I needed to modify my crossmember also but otherwise bolt on 205 from a 87 K-30.
  4. 83ZZ502_Jimmy
    83ZZ502_Jimmy 1/2 ton status
    Feb 7, 2001
    3,103
    Richmond, VA
    The output shaft on the 400/208 combo is shorter than a 400/205 output shaft. You would need to change shafts, which entails dissasembling the entire tranny to do.
    John
  5. Ronnie4wd
    Jun 4, 2002
    749
    Stockholm.Sweden
    I´m not sure but I think there is two different lengths on the output shaft of the 400.
    I did not have to change it .
  6. u2slow
    May 9, 2001
    2,217
    BC Canada
    That is true for 80-84 TH400/205. For 85-90, TH400s use the same (shorter) output shaft for either t-case.
  7. 83ZZ502_Jimmy
    Feb 7, 2001
    3,103
    Richmond, VA
    Good information to know.. Thanks! :)
    John
