TH400 2nd - 3rd shift is screwed up
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Wheeling Arizona, Jun 15, 2002.
  1. Wheeling Arizona
    Wheeling Arizona Registered Member
    Jan 19, 2002
    12
    Chandler, AZ
    My TH400 in my 90 Suburban is acting really strangly with it's 2nd to 3rd shift. Sometimes it is normal...around 40-45mph or so. But that is usually good for only one or two shifts. Then the shift point seems to move much higher, like 65mph or so...and the shift is really mushy when it finally shifts. I have even had it in 2nd as high as 70mph as it fluctuates back and forth into 3rd and out. The shift is not crisp at all...almost a drifting into 3rd and out.
    Any ideas?
    --Steve
  2. Wheeling Arizona
    Jan 19, 2002
    12
    Chandler, AZ
    Starting to suspect a vacuum leak on the modulator. Anybody ever have similar problems? --Help--
    --Steve
  3. arq
    arq 1/2 ton status
    Jan 17, 2001
    2,017
    Imperial Valley/Maricopa
    start with the basics, good source of vaccume, pinched/torn lines, modulator, etc etc...
    ARQ.
  4. rodzzilla
    rodzzilla 1/2 ton status
    953
    Grinnell, IA
    Had a modulator problem w/a TH350. The shift points were higher, but the were also a lot harsher. How is the fluid?
  5. slider
    slider 1/2 ton status
    May 7, 2001
    547
    Whidbey Is. Washington
    Turbo 400's do not have a vacuume modulator, they use a electric switch for kick down. When is the last time the fluid and filter were changed? /forums/images/icons/confused.gif
