TH400 2wd use as 4wd?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Emmettology 101, Feb 21, 2002.
  1. Emmettology 101
    May 9, 2000
    8,126
    FL
    The 2wd version of the Th400, can you use a t-case behind some of these without swapping out the output shaft?
    If so, what cases can be used behind them?
    Thanks!
    Mike
    <a target="_blank" href=http://www.geocities.com/emmettology101>EMMETT</a>
    says: "<font color=green>It ain't easy being Green!</font color=green>
    <P ID="edit"><FONT class="small">Edited by Emmettology 101 on 02/21/02 02:33 PM.</FONT></P>
  2. 83ZZ502_Jimmy
    83ZZ502_Jimmy 1/2 ton status
    Feb 7, 2001
    3,103
    Richmond, VA
    90% sure you can use a 205 behind a short shaft 2WD TH400. The 205 takes a 4.5" oupout shaft. Someone may correct me.
    John
    <font color=blue>"When all else fails, read the instructions, or get a bigger hammer"</font color=blue>
  3. 77fixer
    77fixer 1/2 ton status
    Nov 22, 2001
    464
    Meridian, ID 83646
    That's exactly what I'm doing.
