Th400 2wd?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by mudddog91, May 7, 2002.
  1. mudddog91
    mudddog91 1/2 ton status
    Dec 28, 2000
    471
    north carolina
    Can a th400 tranny thats in a 2wd truck be used in a 4x4?
  2. 4X4HIGH
    Dec 14, 2001
    22,059
    69
    Pleasanton, CA.
    Yes, after you switch out the rear output shaft to a 4x4 shaft.
  3. MudbogAD
    MudbogAD 1/2 ton status
    Jun 29, 2001
    672
    Las Vegas Nevada, US
    Yea, just trade out shafts. I think.
  4. marv_springer
    marv_springer 1/2 ton status
    Aug 3, 2001
    2,781
    Mesa, Arizona
    Funny that you mention this...
    I recently saw an article in one of the mags about an Atlas that bolts directly up to a 2wd T400. Sure, you gotta rob a bank for the purchase of the Atlas case and adapter, but at least the tranny would be cheap....! /forums/images/icons/smile.gif
    Marv
  5. thatK30guy
    Jan 12, 2001
    32,076
    55
    Short tailshaft 2wd 400 tranny's will hook up the short female input shaft on a 205 t-case easily. Both have the shaft stickout of around 4 1/2".
  6. JK5
    Jan 31, 2002
    3,453
    Norton, Oh
    I think the bellhousing is different, so bolting the inspection cover could get tricky!
  7. trukman1
    trukman1 1/2 ton status
    Mar 5, 2002
    129
    Ohio
    The TH400 will work if you have the short shaft tranny and short female input shaft on your 205...I know because I am running one in my truck right now. And for the record, the bellhousings are the same, 2wd vs. 4wd, SBC vs. BBC. It's the Pontiacs, Buicks, Olds, etc. Bellhousings that are different than Chevy's. For good info on this contact www.4xHeaven.com
  8. thatK30guy
    Jan 12, 2001
    32,076
    55
    No, bellhousing are all the same when fitting a BBC or SBC.
    The bellhousing are different when using the 6 bolt dust cover compared to the thinner steel or plastic 4 bolt dust cover.
    Other than that, they are the same unless you get into messing with BOP stuff, then you need a BOP tranny. /forums/images/icons/wink.gif
  9. 77fixer
    77fixer 1/2 ton status
    Nov 22, 2001
    464
    Meridian, ID 83646
    I am also running the short shaft TH400 with my converted 205 short input. Runs great and I even was able to use the inspection cover from my TH350. Gotta love the swapability!
  10. JK5
    Jan 31, 2002
    3,453
    Norton, Oh
    BASICALLY, that is what I ment! Sorry, I didn`t go into more detail.
