th400 -> 4L80E
Discussion in 'The Garage' started by muddybuddy, Feb 1, 2007.
  1. muddybuddy
    muddybuddy 3/4 ton status
    Jan 29, 2004
    8,933
    Fairfax Station VA
    im buying a cucv, which has a th400, and ive got a 4L80E i want to swap in its place. ive already got the diesel computer and wiring harness, and the t-case is already taken care of as well. is there anything else i need? i know ill have to swap the gear indicator from a truck with OD (which i have in my truck that im parting) is there anything else since its going from not having overdrive to having overdrive?
  2. k204dr
    k204dr 1/2 ton status
    Aug 27, 2004
    463
    TN
    sounds like you got it covered.
  3. uao85
    uao85 1/2 ton status
    Jan 2, 2004
    1,867
    Edge of insanity
    when swapping from an old school tranny to a newer 4l80e, atleast in the 2002 4l80e I used, the gear shifter and indicator on the collumn wouldnt work, because it is the opposite throw of the older trannys, atleast it was from my old 700r4. Might be worth looking at. From what I remember, to select gears the linkage pushes the arm to shift through the gear selections, but in the 700r4, the linkage had to pull it into gear. I hope that made sense. It is no biggie though, I just used a B&M megashifter. Although when I swap a 4l80e into my cucv, I am going to try to monkey with it to see if I can get the factory collumn shifter to work right with it.
    Remington
  4. bear76
    bear76 1/2 ton status
    Oct 16, 2005
    1,065
    here
    Muddybuddy, you finally got a cucv. Where did you find it?
  5. muddybuddy
    Jan 29, 2004
    8,933
    Fairfax Station VA
    im working out a deal with a member on here.
    the 4L80E is from a '91 truck with a 6.2 so hopefully everything will work smoothly:D once i get the truck ill be making a build up thread like everybody else:haha:
