th400 and np208 speedo problems..
Discussion in 'The Garage' started by motofool, May 25, 2004.
  1. motofool
    motofool 1/2 ton status
    Apr 7, 2004
    361
    DFW tx
    okay heres teh deal have a th400 with the speedo gear spot plugged witha soft plug and siliconed (came this way)
    and the np208 has the speedo cable going into it.
    speedo dont work tomarrow im gonna pull the cable out of the tranfercase and see whats up...
    so which should i put the speedo cable into i have a spare th400 so i have another gear setup and little housing...
  2. kennyw
    kennyw N9PHW Premium Member
    Jun 9, 2002
    13,224
    94
    Stevens Pass Highway, WA
    You have to keep the speedo on the Tcase or it wont work in 4wd.
  3. motofool
    Apr 7, 2004
    361
    DFW tx
    hrm
    now to figure out why the speedo doesn't work...
    probably a broken gear that is hard to find wiht my luck..
  4. dieselponyexpress
    dieselponyexpress 1/2 ton status
    Jan 26, 2004
    220
    Germany
    Be sure to put the speedo fully into the hole. The O-ring type seal often prevents the cap from being fully inserted. Try with a soft hammer.
    Greetings.Walter
