th400 and np241
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 454Blazer, Aug 3, 2001.
  1. 454Blazer
    454Blazer Registered Member
    Nov 1, 2000
    23
    Albuquerque, New Mexico, USA
    Hi Folks,
    Finally getting around to replacing the th350 behind my 454. I'm getting a th400 and I have an np241. Does the 241 bolt up to the th400? Anyone know what transfer cases were behind th400's?
    <a target="_blank" href=http://members.home.net/snarrlman/index.html>http://members.home.net/snarrlman/index.html</a>
  2. Jason73K5
    Jason73K5 1/2 ton status
    592
    Fresno, Ca
    I picked up a stock 400/241 combo a few months ago, so they will fit. The transmission should be the long output shaft version, but I don't know if there is a difference in inputs on 350 and 400 model 241's. A 350/241 adapter will not fit the 400.
    73K-5: TBI350/TH-400/NP-203/14FF/D44
    Topless, doorless and no tailgate!
    Fresno, CA
  3. johnnysjimmy
    johnnysjimmy Registered Member
    Apr 23, 2001
    47
    The output from the 350 is differant that the 400 so you will need to change either the output from the 400 or the input from the 241
    73' GMC Jimmy 8" lift and 35" tires.....14 boltff and big 10 bolt on the way
