th400 behind a TBI 350
Discussion in 'The Garage' started by wayne, Jul 9, 2002.
  1. wayne
    wayne 3/4 ton status
    Feb 1, 2001
    6,178
    Carlisle, Pa
    Finally putting the 400/205 in now but not sure where to tie in for vaccume (sp) on the TBI intake. Any ideas on this?
  2. Blazer1970
    Blazer1970 1/2 ton status
    1,600
    Old Mission, MI
    If there are no other ports, tee it into the line that goes to the brake booster.
  3. 83ZZ502_Jimmy
    83ZZ502_Jimmy 1/2 ton status
    Feb 7, 2001
    3,103
    Richmond, VA
    You can make as many vaccum ports as needed with some brass fittings from a hardware store. I do it all the time. Plus you can adapt down to the size you need for your hose. Just take the fitting thats in the manifold with you to match up the thread size. Then make what you need.
    John
