TH400 Compatibility question.
Discussion in 'The Garage' started by cbbr, Jun 14, 2006.
  1. cbbr
    Jul 17, 2004
    14,681
    High velocity, Low altitude
    Will a TH400 from an '86 m1008 CUCV (6.2L Diesel/TH400/208) fit a '90 V2500 suburban (350/TH400/241) without modification? If not, what will need to be done to make it fit?
  2. hack500
    hack500 1/2 ton status
    Sep 16, 2005
    523
    Templeton, Ma
    I'm not 100% positive about the length of the outputshaft but if it's the same then you should be able to. you might need to swap modulators and/or governors but everything else should be the same.
  3. MTBLAZER89
    MTBLAZER89 3/4 ton status GMOTM Winner
    Aug 14, 2001
    7,272
    237
    Oak Harbor, WA
    Yeah something is different with the converter I believe Diesels shift earlier. Other than that if it had a 32 spline 208 behind it, and the 241 is 32 spline it should all bolt up.
