th400 dip stick tube removal
Discussion in 'The Garage' started by tomseviltwin, Nov 7, 2004.
  1. tomseviltwin
    tomseviltwin 1/2 ton status
    Dec 23, 2001
    2,065
    Utah
    Th400. Is there a trick to get this off and back on later?
  2. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    there is one tab that bolts to a bellhousing bolt, its the upper one on the pass side, then just pull it out. /forums/images/graemlins/waytogo.gif
  3. tomseviltwin
    Dec 23, 2001
    2,065
    Utah
    Ok its out, I swear I couldn't budge it
  4. js4x4
    js4x4 1/2 ton status
    Jul 17, 2004
    798
    San Diego, CA
    they are a real PITA to get out, theres a tight rubber seal holding them into the tranny. When i removed one...i had to twist pull, twist pull, twist...repeat til its out.
