Th400 Help Wanted
Discussion in 'The Garage' started by 74BBPowerHouse, Jun 26, 2006.
  1. 74BBPowerHouse
    74BBPowerHouse Registered Member
    Mar 17, 2006
    90
    Mount Angel, OR
    Hey I got a ? for you. No one seems to be able to give me the answer im looking for. I have my 74 with the built 454. Well i got 120 miles on the break in and blew the tranny up. It has a th350 and 205 right now. I want to convert it to a th400. What th400's will work for me? I see long shaft and short shafts (dont know the difference). If you know of anybody with one in my area (OREGON) i need the tranny with adapter for a 205 and the linkage im assuming? correct me if im wrong. I just need to know exactly what to get...Thanks for the help.
  2. sweetk30
    Nov 1, 2004
    25,526
    526
    horseheads , ny 14845
    to go th400 swap you need kick down switch setup for gas pedel.
    and then 400 case with the correct 4x4 shaft. also the 400 to 205 adaptor. then need a 32 spline input and have the tcase bored out for the bigger bearing that the 32 spline takes. and a few other goodys.
    i have lots of friends running 454 and th350s . if it is built correctly it should hold up.
    what happened to yours ? and how was it built. ?
    dont forget 400 takes 20 more hp to spin threw bigger parts eating power. also the first and second gear is not as deep.
