TH400 Kick down cable?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by reddog64, Feb 9, 2002.
  1. reddog64
    reddog64 1/2 ton status
    Nov 9, 2000
    3,325
    Federal Way, Washington
    OK... I thought the TH400 had a kickdown cable... someone told me it was electric... I donjt have a kickdown cable on my rig right now... 454/th400... What can i do... i hate downshifting manually... Someone said I have to hook up a switch of somekind? There's a holly carb on there... donno if that makes a difference...
  2. greg83k5
    greg83k5 1/2 ton status
    Nov 2, 2001
    230
    space sity houston, texas
    as i remember, th400s have a kickdown switch on the accelerator pedal bracket down by yer foot........
    * keep the greasy side down *
  3. Smitty
    Smitty 1/2 ton status
    Sep 1, 2000
    999
    Crestview, FL
    TH400s use a factory switch mounted by the accelerator pedal. Lokar also makes a kit that will mount the switch on your transmission with a stainless cable running up to your carb. It's a pretty nice set-up and easy to install. You can get one through Summit.
    Smitty
  4. Zepplin
    Zepplin 1/2 ton status
    Aug 29, 2000
    920
    Bay City, MI 48706
  5. BILLY RAY
    BILLY RAY 1/2 ton status
    Dec 8, 2001
    1,319
    Austin, Tx.
    I WAS TOLD THAT IF YOU PUT IN A GOOD SHIFT KIT YOU SHOULD NOT NEED THE KICK DOWN SWITCH . I SOON WILL KNOW WHEN I AM DONE WITH MY DOUBLER.
