TH400 Kickdown Wires
Discussion in 'The Garage' started by BurbLover, Dec 20, 2004.
  1. BurbLover
    BurbLover 1/2 ton status
    Jul 31, 2001
    3,060
    SW Missouri
    Just converetd my 465/205 to a TH400/208 from a CUCV. There are two wires on the kickdown switch. I'm sure one goes to the tranny and the other goes where? I was thinking eithetr power or ground? Also, which one goes where? TIA!! It's so much nicer not shifting:waytogo:
  2. 83ZZ502_Jimmy
    83ZZ502_Jimmy 1/2 ton status
    Feb 7, 2001
    3,103
    Richmond, VA
    Fused, Ignition switched power
    John
  3. BurbLover
    Jul 31, 2001
    3,060
    SW Missouri
    Thank you. Now I can get everything finished up on some off time.
  4. BurbLover
    Jul 31, 2001
    3,060
    SW Missouri
    1 - Does it NEED to be ignition switch, since it's not on all the time?
    2 - I have an orange wire & a pink w/ black stripe wire. Which one goes to the trannt & which one to the power?
    Thanks.
  5. 83ZZ502_Jimmy
    Feb 7, 2001
    3,103
    Richmond, VA
    The way I'd do it is:
    Ign. Switched off the fuse panel or other source, with in-line fuse to one terminal of the kickdown switch, then the other terminal of teh switch to the plug on the tranny.
    John
