TH400 not kicking down to 2nd gear??
Discussion in 'The Garage' started by Scott A, Jul 13, 2004.
  1. Scott A
    Scott A 1/2 ton status
    Apr 18, 2002
    129
    Monrovia, CA
    I put a test light at the kickdown switch on the drivers side of the trany and it lights up when I push gas pedal down all the way.
  2. Thunder
    Thunder 3/4 ton status
    Jul 20, 2000
    8,946
    Northeast Nevada
    The solonoid inside the trans may be bad. you have to drop the pan to get to it.
  3. Scott A
    Apr 18, 2002
    129
    Monrovia, CA
    drop the pan? bummer /forums/images/graemlins/frown.gif
  4. diesel4me
    Jul 24, 2003
    17,577
    943
    Massachussetts
    Unless perhaps the wire that goes in the tranny to the solenoid is cut or shorted--its on the drivers side of the case--check for power there with the key in the "on" posistion--might be fused too,check the fuses??. /forums/images/graemlins/thinking.gif
  5. Ryan B.
    Jul 18, 2001
    5,693
    CA
    yep check that wire that goes from the switch down to the tranny...
    the connector where it goes to the selenoid inside the tranny could have came loose. (after you pull the pan)
    Otherwise probably the selenoid.
  6. diesel4me
    Jul 24, 2003
    17,577
    943
    Massachussetts
    I forgot to mention that the switch at the gas pedal needs to be depressed (floor it!) to send the juice to that wire--might need a helper or a peice of wood or something to hold the gas pedal floored. /forums/images/graemlins/crazy.gif
