Th400 / NP203 input gear o.d. for Doubler
Discussion in 'The Garage' started by tarussell, Jan 11, 2003.
  1. tarussell
    tarussell 1/2 ton status
    Dec 28, 2002
    1,354
    Bagdad , FL
    I am in need of the input gear o.d. ( the part that goes through the bearing )on a NP203 that has A TH400 32 spline.
    If anyone has this deminsion please share.
    TIA , Tom
  2. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    thought they were all the same.
    I will look up a number for you if i can
  3. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    I only show a single input bearing listed #9422715
    I also only saw input gears for manual tranny #344276 and t350 #6259040
    can you list a model and year for me to search
  4. tarussell
    Dec 28, 2002
    1,354
    Bagdad , FL
    In my parts break down I only saw the bearing # 09422715 too , but I did not trust that there was only one size.
    The only gear #'s that I had were the TH350 one that you listed and the TH400 one part # 00376270. They both show to use the same bearing so - since you show the same info I'll asume that the o.d. is all the same.
    Do you know if that bearing # is the same one used in the 32 spline 205 ? I don't have my 205 paper work with me .
    If they are all the same than I don't need the actual o.d. size - I was just making sure that I had enough meat to open up the spline size for the 35 spline shaft.
    It looks like all of the gears will work one way or another , but I would rather sacrafice a 27 spline gear instead of a more valuable 32 spline piece.
    Thanks for the info , Tom
    P.S. I don't remember the year of my donor 203 but it is a 27 spline and a bolt on yoke w/ a flat flange on the front output so I assume that it is a 1977 to 1979.
  5. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    so you are having the 27 spliner broached to 35 spline?
    I would like to hear your findings on the spline type etc
    broaching costs? who is doing it?
    sorry I came in late here.
    if you have already stated this elsewhere a link to the discussion would be appreciated
  6. tarussell
    Dec 28, 2002
    1,354
    Bagdad , FL
    I'll be using some contacts at work to get the broching done so it will be free , or atleast dollar wise, it's good to have friends that are "true machinest" that owe you favors. I am using the short 35 spline shaft because of the finner splines to cut down on the slop of the drivetrain and it is really short.
    I have the pieces to do a factory 32 spline set up ( 465/208 shaft w/ 6 bolt adapter )but that will be really long and I don't want that. I figure w/ the 35 slpine at the front and the 32 spline at the rear of the doubler than I will minimize the slop effect as much as possible.
    The parts that I am getting from you are going to be put to good use - they will be my first doubler and than go into a different truck once the 35 spline stuff is ready.
    P.S. I just reread your post - I don't know the pressure angle of the invaluted splines yet but I'll be using the original yoke to identify the spline type. Once I get that far I will let you know.
    Thanks for the interest , Tom
  7. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    my concerns on that is the extremely tight fitting splines of the yoke may differ considerably from what is used on shaft couplers.
    definitely no slop.
    I havent yet grilled any of the resident machinists on here about the subject but it has been on my thoughts to hit up Donovan for some info
  8. u2slow
    u2slow 1/2 ton status
    May 9, 2001
    2,217
    BC Canada
    Check the 10-spline input on that 203 for stickout!
    The adapter is what 4" thick? The stickout on a 10-spline the 465 can't be more than 2". So either it has a female input that sticks out of the 203, or it uses a drive-sleeve and a male input.
    I'm not sure which 203 input gear you're broaching out to 35-spline, but make damn sure the 35-spline sm465 output reaches the 203 input gear!
    Here's a pic of a Ford 203... I was just thinking if this input got punched out to 35-spline, the 2wd 465 shaft probably wouldn't reach.
  9. tarussell
    Dec 28, 2002
    1,354
    Bagdad , FL
    Good point on the tight spline fit on the yoke. I'll have a talk w/ the guy doing the cutting to get some feed back- but I am all ears if anyone on this board has some machinest info......
    The 27 spline that I intend to get cut does stick out a bit , but I will loose some of the protrusion(sp) do to the end being to thin at the beginning.I will know how thick( or I should say how thin )the adapter will need to be when I get to spend some quality time in the garage. I am thinking that I need a minimum of an 1-1/2" spline engagement. What do Ya'll think ?
