TH400+NP203
Discussion in 'OffRoad Design' started by realsquash, Apr 3, 2001.
  1. realsquash
    realsquash 1/2 ton status
    Jul 12, 2000
    778
    SE WI
    I looked high and low, and I can't find a definative answer to this question. I want to know if a TH400 that had an NP203 and a TH400 that had an NP205 have the same output shafts. I gather that they are both 32 splines, they both require the short shaft, and the adaptor->400 case pattern is the same.
    Thanks,
    Squash
    <A target="_blank" HREF=http://www.trailrunners4x4.org/users/realsquash>http://www.trailrunners4x4.org/users/realsquash</A>
  2. thatK30guy
    Jan 12, 2001
    32,076
    55
    I have a 400/203 combo sitting on my floor now. I just sold a 400/205 combo in Jan. They have the same spline count, but the shaft sticks out further on the 205 than the 203. If I remember right, the 205 shafts sticks out about 4 inches. Not sure here, but definitely know the 203 shaft is shorter than the 205. Ask Stephen, he can tell you the exact answers.
  3. realsquash
    Jul 12, 2000
    778
    SE WI
    See that is the other thing that I have discovered but forgot to post. There are 2 output shafts for the NP205 version TH400. A long and a short!
    Squash
  4. BIGCHEVY
    BIGCHEVY Registered Member
    Dec 10, 2000
    31
    MANITOBA,CANADA
    the output shaft on the th400 that bolts to the 203 is a 32 spline short shaft. i know this from experience. i just took my th400 np203 out of my truck today. it is definately the short shaft. hope this helps ya!:):)
    IF IT AIN'T BROKE,YOU AIN'T TRYING HARD ENUFF
  5. Bigd
    Bigd 1/2 ton status
    Apr 3, 2000
    399
    Co,Colorado Springs
    ON my t400 and 203 combo the shaft on the tranny sticks out about a 1 1/2 inch.The t400 205 version that i have seen the shaft stuck out about 4 inchs.
  6. thebigdaddyof2
    thebigdaddyof2 1/2 ton status
    Dec 28, 2000
    2,053
    St. Louis, Missouri
    So, if we agree the output shaft for the 400/203 is 1.5" and the output shaft for the 400/205 is 4", does it stand to reason that you could cut off the 4" shaft..... if going to the doubler??
    Or, would there be an issue of the placement of the splines?
  7. thatK30guy
    Jan 12, 2001
    32,076
    55
    I doubt anybody should ever try to attempt this procedure. The heat generated from the saw blade is enough to weaken the hardened shaft. You would also have to dress up the splines from the burrs from the cut.
    I have seen someone cut the shaft on a car tranny to fit a truck 4x4 and it did not last. Guess the vibrating saw messed up the pump somehow. The guy pulled that tranny out three times and messed with it and installed it back in each time. Today that truck is parked with the tranny and t-case OUT of the truck. Reason enough NOT to try any cutting of any sort.
  8. RUSS84K5
    RUSS84K5 1/2 ton status
    Jan 9, 2001
    172
    NEW HAMSHIRE
    If you are able to get the shaft out of the tranny, use a band saw and lots of oil and it probably won't get too hot.
    Russ V
  9. RGF
    RGF 1/2 ton status
    Jan 5, 2001
    281
    Maine
    The problem with cutting off the shaft is not a heat issue, its about having not enough spline contact when your done! I think the lenghts that the others posted were correct or close to it @ 1.5 on the 203 and 4" on the 205 TH400s. So that means you would have to cut 2.5" of spline off the shaft and thats probably not going to leave much spline left to engage the input on the transfer if any that all!!! The only way to do it correctly is to change the output in the tranny and that requirers taking it down to the bare case.
    RGF
