TH400/NP205 adapter mod
Discussion in 'OffRoad Design' started by Jimbo*, Dec 29, 2005.
  1. Jimbo*
    Jimbo* 1/2 ton status
    Mar 8, 2005
    1,420
    roswell, new mexico
    Hey Stephen, I noticed on your Sale Page that you now have TH400/NP205 adapters available. I assume these are aftermarket, and as such could you modify a few of these to fit 4L80E? I would buy one, and I'm sure you would no problem moving the rest of them. So what say ye?
    Thanks, Jimbo
  2. Jimbo*
    Mar 8, 2005
    1,420
    roswell, new mexico
    Bump to the top in hopes someone will answer; If not, I'm going to head into the machine shop and figure it out myself.
    Jimbo
  3. Muddytazz
    Muddytazz 1 ton status
    Jun 30, 2002
    20,073
    Salem, Or.
    Might get a faster answer if you were to call them.
  4. sweetk30
    Nov 1, 2004
    25,554
    548
    horseheads , ny 14845
    the main diffrence is the lip for the seal to sit on. just look at both and make the other match the 4l80 unit. i used a 2x4 fixed yoke 4l80 and made a spacer to the 400 205 mount so i didnt need to change the shaft out. the spacer is 4l80-e on one side and 400 on the other side.
    if you are changing from 2x4 tranny you need to change out the plug that has pin hole to lube the tail bearing to a solid plug as 4x4 dont need that. if not changed tranny damage will happen as a gm master tech told me.
  5. Jimbo*
    Mar 8, 2005
    1,420
    roswell, new mexico
    SweetK30, Thanks for the info, I think I'm going to do this myself. I'm working on round pattern adapters, and can make this work pretty easily. One question, if you don't mind; What is the length of your figure 8 adapter from tranny side to t/c side, not including your spacer?
    Thanks, Jimbo
  6. NorthWestFab
    NorthWestFab 1/2 ton status
    Jan 11, 2005
    311
    Canada Eh.
    Factory Figure 8 TH400 / NP205 Adaptor is 4.00"
  7. Jimbo*
    Mar 8, 2005
    1,420
    roswell, new mexico
    to NWF, THANKS!!!
    Jimbo
