TH400/NP205 Adaptor (PLEASE READ)
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by KRAZIE87K5, Jul 16, 2001.
  1. KRAZIE87K5
    KRAZIE87K5 1/2 ton status
    Feb 23, 2001
    3,369
    Chicago, IL
    Take a look at the pics below... I am assuming my adaptor is not complete, because the crossmember I have does not even come close to meeting the adaptor! Here is what I have in the truck...
    Adaptor Close up:http://24.10.209.54/images/86truck/trans/missingmount1.jpg
    Cross member:http://24.10.209.54/bigolk5.htm [​IMG]
  2. KRAZIE87K5
    Feb 23, 2001
    3,369
    Chicago, IL
    BTW... The adaptor is 6 bolts on both sides... 32 spline output on the TH400.
    Does anyone else smell BFGs burning???
    454/TH400/NP205 - 14BFF/D60/w/ 4.10s
    <a target="_blank" href=http://24.10.209.54/bigolk5.htm>http://24.10.209.54/bigolk5.htm</a> [​IMG]
  3. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    Is this a new swap from a Turbo 350 setup? I had to drill new holes for the crossmember when I installed my Turbo 400/NP205 combo.
  4. 502Burban
    502Burban 1/2 ton status
    Jun 8, 2001
    379
    Southern California
    Since your K5 didn't come with a big-block, TH400/NP205 combo, you will have to re-drill the crossmember mounting holes in the frame. The new combo is longer, overall, than the stock combo. Also, you will need the transfer case/transmission mounts that go between the adapter and the crossmember. I like the urethane ones from Energy Suspension, part number 3-1106, but of course you can always run some stock replacements. Those two issues should fix your problem.
    Good luck. [​IMG]
    Robb
    '73 GMC Suburban - 502DFI
    <a target="_blank" href=http://community.webshots.com/user/robbrj>community.webshots.com/user/robbrj</a>
  5. elkboy
    elkboy 1/2 ton status
    Aug 18, 2000
    293
    Hillsboro Oregon
    look at the install pic, it's a 350/205, but it should be close to yours.
    <a target="_blank" href=http://y42.photos.yahoo.com/bc/nepatten/lst?.dir=/Project+K5&.view=t>http://y42.photos.yahoo.com/bc/nepatten/lst?.dir=/Project+K5&.view=t</a>
    <font color=red> Elkboy </font color=red> 82 K5 fuel injected H.O.305, TH350/205, 14bolt/10bolt and 39.5 TSL's.
  6. Donovan
    Donovan 1/2 ton status
    524
    Arvada, CO
    I think that you are missing the correct crossmember. I have a 78 TH400 hooked to a 205 and it does not look like that. I also have a 86 1 ton truck and it has a 6 bolt adapter just like that but it has a 4 speed in front of it. The crossmember is a w-shape instead of a u-like shape. What I mean is the center of the crossmember comes up about 2-3". I doesn't look like the 79 and earlier crossmember. I hope that helps some.
    Donovan
    Bigger is Better
  7. Jason73K5
    Jason73K5 1/2 ton status
    592
    Fresno, Ca
    Your crossmember should work fine. I just swapped a th400/203 combo into my '73 which has essentially the same adapter mount as your combo. I also have the same crossmember as you. All I did was bolted the crossmember to the adapter and then jacked everything up untill the crossmember was mating the frame. Then I just drilled new holes and bolted it up.
  8. thatK30guy
    Jan 12, 2001
    32,076
    55
    From the looks of that adaptor, that is an '85 to '91 K30 np205. To run a crossmember under that adaptor, you need to find the 'double hump' member from an '85 or '86, or, from an '87 to '91. I sold an '86 crossmember last week. I have an '87 crossmember sitting on my shed floor. It is all you need to make the thing work. You would also need the rubber mount that sits between the member and bottom of the adaptor. I do not have one. You can get these from GM too. I can sell you the '87 crossmember for $40.00 and you pay shipping.
    Anybody planning on checking out my homepage, forget it, I am still working on it!!!
  9. KRAZIE87K5
    Feb 23, 2001
    3,369
    Chicago, IL
    I'll take it! Please call me at 630.373.0190 ASAP!
    Thanks a bunch!
