TH400/NP205 ????'s
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by magnum4x4, Oct 3, 2004.
  1. magnum4x4
    magnum4x4 Registered Member
    Jan 4, 2004
    97
    Baltimore, MD
    TH400/NP205 ????\'s
    I was wondering the difference between the late 70's 400/205 setup and the late 80's 400/205 combo. Are they the same except the crossmember. Can I put a late 80's combo in my 73 K5 with minor mods. Are the output shafts and adapters the same. Can a late 80's 205 go on a late 70's 400? Thanks for your help.
  2. boz42
    boz42 1/2 ton status GMOTM Winner
    Jun 3, 2003
    3,181
    Hopewell, Tn 38058
    Re: TH400/NP205 ????\'s
    can't answer all your questions, but here is what i know.
    late 70's has an hour glass style adapter on the 205 side & a shorter tail shaft.
    late 80's uses a longer tail shaft in the t-400 & the 205 & adapter have a round bolt pattern.
  3. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Are they the same except the crossmember(?)
    No
    Can I put a late 80's combo in my 73 K5 with minor mods(?)
    Yes.
    No, the output shaft on the newer one is longer and the bolt pattern on the front of the transfer case is different. That is why the crossmember is different.
    Yes, but you'll need to do two things:
    1. Change the output shaft in the TH 400
    2. Use the newer adapter.
    This information is all available on ORD's website at www.offroaddesign.com
