TH400/NP205??????
Discussion in 'The Garage' started by Corey 78K5, May 25, 2003.
  1. Corey 78K5
    Corey 78K5 1 ton status
    13,055
    Humboldt County, CA
    What years had this combo and which trucks are the best ones to look for.
    I about pissed myself yesterday when I was at the junk yard pulling a set of Warn hubs off a 74 K-20 when I looked under it to see if It had My dream tranny. Sure enough it was an SM465/NP203. Now all I need is a TH400 version 205. I know I can convert any 205 with the kit from ORD but I want to save some money.
  2. thatK30guy
    Jan 12, 2001
    32,076
    55
    1980 on the 3/4 and 1 tons.
    1981 to 84 on the 1 tons only in order to be able to do the Doubler setup.
  3. Corey 78K5
    13,055
    Humboldt County, CA
    So from what Your saying My best bet would be to get a conversion kit from ORD. Hell the kit is only like $200. I'm getting the 465/203 for free /forums/images/graemlins/thumb.gif and I can also get any 205 I want for free also /forums/images/graemlins/thumb.gif. My buddie owns the local junk yard and always owes Me for doing favors for him.
  4. Silver84k5
    Silver84k5 1/2 ton status
    Feb 7, 2002
    3,769
    Hillsboro Oregon
    How come the doubler will only work with the 81-84?
  5. Corey 78K5
    13,055
    Humboldt County, CA
    What Wes means is the only NP205 that will work with a Doubler is the TH400 version because it has a 32 spline female input gear. Which is what you need to mate to a 203 range box. Or you have to convert another 205 to the 32 spline female input gear.
  6. thatK30guy
    Jan 12, 2001
    32,076
    55
    Well, if you don't have any luck locating the proper 205, then yes, it would cost the same, if not cheaper, to get the conversion kit. Just remember, the input bearing bore on the case housing will need to be enlarged to fit the 32 spline sized bearing. /forums/images/graemlins/wink.gif
    And no, I don't have any of these short input 32 spline 205's either. /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif
  7. Silver84k5
    Feb 7, 2002
    3,769
    Hillsboro Oregon
    Oh i knew why you had to have the th400 verion 205 but....
    It sounds like hes saying only the 81-84 th400 version 205 will work for the doubler..... why is that? Is that because that is the only 205 that has the 32 spline input? so the 1980 th400 205 has a different spline count?
  8. thatK30guy
    Jan 12, 2001
    32,076
    55
    Corey said it right there. 1 tons from '80 to '84 are the ones that use the "tall" adaptors which sit on the flat crossmembers. These are the highly desired t-cases to mate to the Doubler.
    The '85 to '91 205 t-cases are a longer input shaft and use a 6 bolt round pattern adaptor. These are the "short" adaptors and sit on a double hump crossmember. /forums/images/graemlins/thumb.gif
  9. thatK30guy
    Jan 12, 2001
    32,076
    55
    No, because the '80 years, the 205's were available in BOTH 3/4 AND 1 ton trucks. /forums/images/graemlins/wink.gif
  10. Corey 78K5
    13,055
    Humboldt County, CA
    Damn Wes Your smarter than You look. /forums/images/graemlins/wink.gif /forums/images/graemlins/thumb.gif /forums/images/graemlins/rotfl.gif
  11. thatK30guy
    Jan 12, 2001
    32,076
    55
    /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif /forums/images/graemlins/thumb.gif /forums/images/graemlins/wink.gif
