TH400 output shafts... 205? 208?
Discussion in 'The Garage' started by jekbrown, Nov 15, 2005.
  1. jekbrown
    May 19, 2001
    45,031
    366
    Vancouver, WA, USA
    Going to look at an 81 burb that probably has a 208 tcase in it... guy says it has a th400. My TH400 manual shows three potential output shafts... the 32 spline short (about 1.25" of actual splines) and another 32-spliner that has 2.5" of splines... and finally the long mofo... which has like 2" of splines, but has a total length of like 9.25". If it has a 205 Im just gonna grab it ASAP... but if its a 208 I still might consider it depending on the tranny output shaft situation. If it has a 208, anyone know which output the tranny will have? Can you get differen th400 outputs and just swap them in? expensive?
    j
  2. jekbrown
    May 19, 2001
    45,031
    366
    Vancouver, WA, USA
    come on now, surely someone has a th400/208 combo and can tell me what size the shaft is? :confused:
    j
  3. thebigdaddyof2
    thebigdaddyof2 1/2 ton status
    Dec 28, 2000
    2,053
    St. Louis, Missouri
    From the ORD website:
    GM TH400 Automatic Transmission:
    If you have a TH400, there are three options for mating the 203 to your trans.
    1: Use a factory configuration. The TH400 was available with the NP203 in heavier duty trucks (3/4 and 1-ton generally) in approximately '78-'79. The factory configuration uses a 1 3/8" stickout 32 spline shaft in the TH400, a 32 spline input gear in the NP203 and a 1.1" adapter plate between the two, somewhat similar to the TH350 adapter plate. This is the shortest way to mate the TH400 and NP203.
    2: Use a TH400 that originally had an NP208 mated to it. This TH400 uses a 32 spline shaft that sticks out of the case about 2.5" and has an adapter housing that's about 2.5" thick. You'll use a TH400 version 32 spline input gear in the NP203 and re-drill and tap the face of the NP203 with the round bolt pattern to match up to the NP208 adapter housing. Benefits of this kit are the parts are quite common since the NP208 was very widely used with TH400 trannies. The drawback is the adapter is about 1.5" longer than the shorter factory configuration.
    3: Use a TH400 that originally had a NP205 behind it. This TH400 uses a 32 spline shaft that sticks out about 4.5". You'll need to use a factory TH400 to round pattern NP205 adapter housing that is 4" thick and once again, re-drill the front face of the NP203 to match the round pattern. The input gear will be the TH400 version NP203 32 spline input. Drawbacks to this system are the overall length with the 4" housing between the two and the expense of buying the factory housing. They're not common as used parts and typically must be purchased new. ORD can supply this adapter.
    The only version that's not talked about here is the later models with the round pattern NP205. IIRC, this 205 had the long input but used the same 2.5" shaft stickout as the 208 version.
    To swap the output shafts, a complete teardown is required.
