th400 pan w/temp sensor bung?
Discussion in 'The Garage' started by broncoman6524, Mar 24, 2007.
  1. broncoman6524
    broncoman6524 1/2 ton status
    Oct 31, 2005
    2,469
    chuluota Fl
    anybody know who the hell makes one!? i cannot seem to find one anywhere, summit google no luck :confused: am i being forced to drill tap and/or weld a bung into the pan?
    thanks guys
  2. sweetk30
    Nov 1, 2004
    25,546
    542
    horseheads , ny 14845
    b&m drain plug kit. it has a 1/8 pipe thread plug in it. it is the same size as the sender unit.
    but to get true info on hot tranny you need to read the output line temp going to the cooler.
  3. broncoman6524
    Oct 31, 2005
    2,469
    chuluota Fl
    hmmm soo i *could* in essence make some kinda like piece that goes in between the tranny and tranny cooler line? and put the sensor in that way? or i guess i could just guestimate the "real" temp as comp to the gauges temp. and just round upwards. the safe temp is somewheres around 150-200right?
  4. sweetk30
    Nov 1, 2004
    25,546
    542
  5. broncoman6524
    Oct 31, 2005
    2,469
    chuluota Fl
    i just bough a 10 gauge at the local rod show this weekend...theres no T-fittings in it :( is this something that i could get at Home DEpot? just like a brass T-style connector right?
  6. sweetk30
    Nov 1, 2004
    25,546
    542
    the tee fitting will have a 1/4 pipe thread bung on the center outlet. then you need a 1/4 pipe to 1/8 pipe reducer. might be kind of hard to find. also it needs to be 5/16 compression fittings on the ends if your tranny cooler lines are stockers.
  7. jekbrown
    May 19, 2001
    45,031
    366
    Vancouver, WA, USA
    you can get remote tranny filter doo-dads from Summit than come with a temp sensor "port" in them already.
    summit part #...
    PRM-10678
    run a line from the trans, to the filter, then on to the cooler. No drilling, tapping, welding or anything else required.
    j
