TH400 pros ever heard of this?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Md mudder, Apr 1, 2002.
  1. Md mudder
    Md mudder 1/2 ton status
    Sep 29, 2000
    139
    my buddy has a th400/208 from a cucv in a 67 IH travall just bought it has a b&m racing shifter when he puts it in drive it it takes off in 2nd he rolls slow in 2nd pulls the shifter to first the rear tires lock up. pull the shifter to 1st from a stop it won't move just rev. acts like to me that the 1st gear is locked but I have never heard of this in a auto. any ideas?
  2. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Sounds like he's got the shifter mounted incorrectly or it's a reverse pattern shifter and what he thinks is 1st is really PARK!!
  3. Ryan B.
    Jul 18, 2001
    5,693
    CA
    Yeah something ain't right.
    Get under the truck and disconnect the shifting linkage.
    Start up the truck and with one guy holding the brake!
    ... Get under there and manually shift the detent lever so you can find out Which direction the P-R-N-3-2-1 OR P-R-N-1-2-3 if it's a reverse shifting valve body. You won't be able to figure out if its 123 or 321 without taking it for a drive while leaving it in one of those positions.
    You said that he puts it in Drive or the 3rd gear position and it takes off in 2nd? usually manual valve bodys will take off in whatever gear it is in... like if you leave it in 3rd it will take off in third not 1st.
    It sounds like the shifter cable linkage is messed up or not adjusted properly..
    <a target="_blank" href=http://communities.msn.com/Ryans1972Blazer/th400transmissionrebuild.msnw?action=ShowPhoto&amp;PhotoID=408>Here's instructions how to adjust the Shifter cable. /forums/images/icons/smile.gif</a>
    Hope this helps dude.
  4. mnstr_fx
    mnstr_fx Registered Member
    Sep 13, 2001
    78
    IL
    If the linkage thing does not work out, it might be with the shift kit. What I am implying is not that the kit is bad but the guy who installed it messed it up. A friend of mine "finished" putting a Th400 that we started to rebuild. Started, ran ok had 1 and 2 but 3 was a dead lockup. He "added" an extra spacer plate on me. Took it out, trannys OK!! /forums/images/icons/smile.gif
  5. Md mudder
    Sep 29, 2000
    139
    thanks for the ideas I'll try disconecting the cable and put it in first at the shift lever
