th400 question
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by lv2whl, Aug 29, 2001.
  1. lv2whl
    lv2whl 1/2 ton status
    Mar 4, 2001
    130
    CA, USA
    i have a question, how hard would it be to convert a 2wd th400 to accept an np 203 out of a '76 k5. what would i have to change? thanks.
  2. pr1aw
    pr1aw 1/2 ton status
    Sep 17, 2000
    144
    San Diego CA
    A tranny teardown/rebuild, tailshaft from a 400 that will slide into the 203 and the tailshaft housing to bolt up to the 203.
  3. DesertDueler
    DesertDueler 1/2 ton status
    May 23, 2001
    3,106
    Phoenix, AZ
    You need to switch the output shaft on the th400 to a 4x4 shaft. You will also need the adapter bracket to bolt them together, unless you have it already. But on the tranny just the output shaft.
    86 Jimmy 4"lift 35"MTRs Other cars 69Firebird w/525 hp,and 70GTO live in PHX,AZ<a target="_blank" href=http://www.geocities.com/modifierperformance>My vehicles</a>
  4. 83ZZ502_Jimmy
    83ZZ502_Jimmy 1/2 ton status
    Feb 7, 2001
    3,103
    Richmond, VA
    I agree with the others. A complete tranny teardown is required to swap in a tailshaft. It is the first thing to go in and the last to come out.
    JH
    '83 GMC Jimmy 4x4 ZZ4 Crate Motor
    '83 Chevy K20 Sand Drag Racer, 578 RWHP
    '94 Impala SS
    '01 Chevy 2500HD 4x4 w/8.1L & Allison Auto
