TH400 Question
Discussion in 'The Garage' started by Smitty, Dec 7, 2003.
  1. Smitty
    Smitty 1/2 ton status
    Sep 1, 2000
    999
    Crestview, FL
    Is there any difference in the TH400 found behind a 6.2 and one behind a small block? Checking to see if they're direct swaps. Might be a dumb question but I don't have the two together to compare.
    Smitty
  2. 4X4HIGH
    Dec 14, 2001
    22,063
    71
    Pleasanton, CA.
    The tranny will swap, not sure if there are any internal differences though.
  3. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Not really, but the TC stall speed is much lower IIRC.
  4. bigred81
    bigred81 1/2 ton status
    Dec 5, 2003
    323
    Falls City,TX
    The transmission is the same but the torque convertor has a different stall speed. I ran in to this when I went with a big block in my brother truck. We ended up putting in the torque convertor for the big block so that we would not ruin his freshly rebuilt th400. The th 400 torque convertor from a 350 motor would hook up faster but you run the risk of blowing up the torque convertor behind a diesel and a diesel torque convertor is build to take the torque that a diesel produces at low rpm. To answer your question yes it is a direct swap in. Hope this helps you without confusing you.
    James Startz
  5. 4X4HIGH
    Dec 14, 2001
    22,063
    71
    Pleasanton, CA.
    You cannot compare the stall speed of the TC just by looking at them so I am sure he wanted to know if the trans will physically bolt up.
  6. dyeager535
    26,982
    191
    Typically a diesel will have much lower shift points than a gas version as well. This is done with the governor.
  7. dhdescender
    dhdescender 1/2 ton status
    Aug 10, 2002
    628
    Qualicum Beach, British Columbia, Canada - Eh.
    Yeah, a stock Gas Torque converter behind a diesel is a little bit risky, its not meant to take the torque the diesel puts out. Vise vera however, diesel torque behind a gas motor will work fine if your motor has the power to fight the lower stall speed of the converter.
    I'm running a 1400-1800rpm Stall 540-3 Severe Duty Allison converter with my Th400. This gets me machined splines, solid steel stator, and brazed fins. In other words, one kickass torque converter meant for a 5 ton.
  8. boz42
    boz42 1/2 ton status GMOTM Winner
    Jun 3, 2003
    3,181
    Hopewell, Tn 38058
    not trying to high-jack, but i thought diesel engines had BOP bell housing patern?
  9. Smitty
    Sep 1, 2000
    999
    Crestview, FL
    Want to thank everyone for the info. I was planning on going with an aftermarket torque convertor so it shouldn't be an issue. If I replace the gov will it eliminate the problem of different shift points or is there any other mechanism that will need to be replaced/adjusted?
  10. dhdescender
    Aug 10, 2002
    628
    No, only the only 5.7L olds diesels did. 6.2's and 6.5's are a chevy block.
  11. dyeager535
    26,982
    191
    I think the governor is all that needs to be adjusted. You can buy governor recalibration kits to retune your shift points.
    Not sure if all TH400's use the same drive gear for the governors, if they do, then you could just swap in your old one (if you have one) and be done with shift points.
    You can buy adjustable modulators, but at WOT, the difference between the two extremes of the adjustment was a whopping 5MPH, hardly worth it.
