TH400???'s
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by magnum4x4, Sep 27, 2004.
  1. magnum4x4
    magnum4x4 Registered Member
    Jan 4, 2004
    97
    Baltimore, MD
    TH400???\'s
    Will a th400 thats behind a 6.2l diesel bolt up to a 350? If not what do I have to do to make this work?
  2. dhdescender
    dhdescender 1/2 ton status
    Aug 10, 2002
    628
    Qualicum Beach, British Columbia, Canada - Eh.
    Re: TH400???\'s
    Yes it will bolt up, the bellhousing pattern is the same. The diesels used a different stall toruqe converter.
    I'm fairly sure the shift points are set differently on the diesel TH400, but I can't confirm that.
  3. rodzzilla
    rodzzilla 1/2 ton status
    953
    Grinnell, IA
    Re: TH400???\'s
    I'm pretty sure they have different govenor settings, too.
  4. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    Re: TH400???\'s
    diesel trans have different governor settings and all since diesels don't rev nearly as high as a 350.
  5. Kyle89K5
    Kyle89K5 1/2 ton status
    2,273
    OKLAHOMA
    Re: TH400???\'s
    What all needs to be swapped besides the gov and the convertor?
    KP
  6. Ryan B.
    Jul 18, 2001
    5,693
    CA
    Re: TH400???\'s
    swapping the governor from a gas transmission, is as easy as unbolting the 4 bolts for the governor cover, and sliding out the governor, with the centrifigual weights on one end and the plastic drive gear on the other end.. the weights in the governor assembly should be responsible for how quickly the tranny builds governor pressure and when it shifts. /forums/images/graemlins/thumb.gif
