Th400/Sm465/Np205
Discussion in 'The Garage' started by Aquaman, Nov 16, 2004.
  1. Aquaman
    Aquaman 1/2 ton status
    Apr 21, 2002
    337
    Kansas City, MO
    Contemplating this swap. Seems as though it would not cost me all that much to do, but (of course) I always forget the vitals. What this would involve is finding a 4wd Th400, making an adapter (rear of th400 to front of sm465), and having a custom shaft machined for the th400 output, and sm465 input. Then it would be a matter of hooking up shifters and such. Would this be all as far as installation?
    Would it really work very well? I sort of wonder whether the sm465 would be able to handle all the torque from the th400 reduction. But some people go with sm465/sm465 set-ups, so why not?
    What are ya'll's thoughts on this subject? I think I can do this... /forums/images/graemlins/waytogo.gif
  2. diesel4me
    Jul 24, 2003
    17,534
    920
    Massachussetts
    I've seen several home built tractors using two tranny's in a row,but both tranny's were standards(not that it would make much difference)but a few of them broke the input shaft off the second tranny--seems the tourque of an engine is all they were designed for(about 400ft lbs).Once you run that 400ft lbs thru the first tranny in first gear,you multiply it many times--a SM465 has 6.54 to 1 in low gear,so if you had 400 ft lbs it would be mutiplied 6.54 times that,making in the vicinity of 2500 ft lbs!going into the front of the second tranny--thats why a lot of them break,simply too much tourque overload. I think you would need a huge tranny for the second one,like a big rig diesel one that could handle the tourque--it would be very heavy and cumbersome though.It would be neat to put the Th400 in drive and select your crawling range with the rear tranny though!--3 speeds in every range,including reverse--and if you put both tranny's in reverse,it goes foreward at VERY low speed!.The rear axle probably wont like all this tourque either though--might need a huge rear axle to go with all that tourque,like one from a big bus or farm tractor.It would be neat if you can make it durable enough to last--most of the tractors I saw used 10 wheel dump truck 2 speed axles ,and the same trucks tranny for the second tranny,they held up ok..but they weighed a lot!. /forums/images/graemlins/crazy.gif
  3. Aquaman
    Apr 21, 2002
    337
    Kansas City, MO
    It would most likely require 1410 U-joints, which in turn would let me do a square tube shaft conversion (easy). Might be able to keep the strong 4.56 gears I already have, rather than going with 5.38's. I don't know. I am still planning that stage in the build. I need to get it wheeling ASAP. Collecting more parts every week.
  4. dhdescender
    dhdescender 1/2 ton status
    Aug 10, 2002
    628
    Qualicum Beach, British Columbia, Canada - Eh.
    If you could get something he size of a 32 input on the SM465 t might hold up. The tiny ten spline that indexes into the clutch is just too small to take the torque multiplication.
    You going to run a clutch, or just match the RPM's?
  5. burbBoy
    burbBoy 1/2 ton status
    Feb 4, 2002
    358
    WI
    The input shaft will break in time. I ran the 465/465/205 for a while tile the input shaft sheared off. My original plan was just as yours but i didnt have a good TH400 around. You would need no clutch if you just use the 465 as a reduction box. Picking a gear and then leaving it until stopped.
    As for a shifter...all i did is cut one down to use on my second tranny.
    Keep us posted on your progress if you decide to go ahead with it.
  6. dhdescender
    Aug 10, 2002
    628
    If somone went out of their way to make a custom inpout shaft 32 spline female, (you'd need new retainers and bor ethe case), it *might*, I say *might* hold up.
    You'd probably start eating the internals of the 465 for lunch. 32 spline would be key, as you could bolt a 465 behind another 465 or a TH400. I think you'd survive behind a TH400, as the most multiplication you'd get is 2.5:1 first gear. That said, there is a toruqe converter too.
    Or a 465/420 if you really want a short driveline.
    I would estimate that the custom shafts alone for the swap would be $500 or more, and thats doing decent QTY's.
  7. Aquaman
    Apr 21, 2002
    337
    Kansas City, MO
    I think I'm going to scrap this one. I'll just find a way to clock my current 205, and put a divorced 205 behind it I guess.
