TH400 swap in to replace 700R4
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Brian 89KBlazer, Jul 19, 2001.
  1. Brian 89KBlazer
    Brian 89KBlazer 1/2 ton status
    779
    Ontario, Canada
    I know it's been discussed here & there in pieces but does anyone have a step by step & part by part description/write-up on this swap?? Either that or if there were details given in a previous CK5 post, what's the link?
    My tranny supplier is sending all I need in hard parts but is sending me a 32 spline input gear for my t-case instead of a 27-spline output shaft for the TH400 along with the correct adapter plate. He didn't seem to think I needed the B&M kickdown kit. Just vacuum for the modulator. Wes, anyone??
    Brian
    89KBlazer
    Build it Right or Don't build it at all!!
  2. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    The Turbo 400 uses vacuum to the modulator to help control shifting. You'll need to wire up a switch to get the kickdown for passing gear to work. It mounts on the gas pedal bracket. I grabbed the switch for mine from an old Jeep Wagoneer. Lots of those are laying around in junkyards and most came with Turbo 400's. The switch from the Jeep bolted directly to the bracket on my K5. [​IMG]
  3. CK5
    May 19, 1999
    21,623
    701
    CO
    I plan on swaping my 700 for a 400 but I am going with a manual valve body. would I still need the modulator?
    Steve
    Bandwidth FREE ZONE
    Mall-Running poseur 4x4 with curb-feelers
  4. Brian 89KBlazer
    779
    Ontario, Canada
    Thanks Harry
    I should have remembered that from a long ago post! [​IMG][​IMG]. Now I remember; both ARE needed. So that bracket kit from B&M racing basically just relocates the kickdown switch from the gas pedal to the end of the the 700R4's throttle cable in the engine bay, correct??
    Thanks again
    Brian
    89KBlazer
    BTW, when are you swapping Steve? I need a write up with pics by mid-late August. please!![​IMG][​IMG]
  5. ken
    ken 1/2 ton status
    1,244
    Anaheim, CA
    I did this very swap a few months back in the wife's '90 Suburban. It had the dreaded 700r4 in it. The 32 spline input shaft must be installed into your 241 transfer case, and it has to be split open to install it. No biggie, just stand it on its end (the end that mates to the trans) and pull all the bolts and slowly seperate the case halves and look inside when you have it open only about an inch to see where everything is. About the only thing that needs to be lined up is the shift fork. Also, one tip, loosen the front output flange nut before you remove the transfer case from the truck, this will make it alot easier...also tighten it back again once its installed in the truck and you have some resistance to hold it from turning. If I remember correctly, the torque is 150 ft/lbs. Be sure to insure that you received all the correct parts, namely that the ourput shaft from the 400 has enough engagement into the input of the transfer. There were some 4x4 versioned 400s that had longer outputs than others.One nice thing is that I did not have to modify my driveshaft lengths or the crossmember mounting in any way...it was pretty much a bolt in! Good luck!
    ken
  6. 4x4blazer
    4x4blazer 1/2 ton status
    Jun 14, 2000
    278
    Louisiana
    You may also want to replace your gear indicator on your column. I got mine from a '77 Chevy pickup and it fits perfect.
  7. HarryH3
    May 31, 2000
    10,384
    Georgetown, TX
    Steve, I'm not sure if you need a modulator when running a manual valve body. I think the modulator also controls hydraulic pressure in the tranny, so it's probably required, even if you will do all the shifting yourself. No big deal since it's part of the tranny anyway. Just run a vac line from the intake manifold to the modulator and you're all set. [​IMG]
  8. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    No, you don't need a modulator with a manual valve body. There wouldn't be any hydraulic control going on at all--a full manual valve body is just that--completely manual. Vacuum or nothing else--except input from the driver--is going to affect the shifts.
    Tim
  9. HarryH3
    May 31, 2000
    10,384
    Georgetown, TX
    Does the manual valve body also override the line pressure? Some trannies increase the line pressure with load, to increase the clamping power on the clutches.
  10. ChadH82
    ChadH82 1/2 ton status
    May 9, 2001
    400
    Stillwater, Oklahoma
    If I'm starting all over with a new 400 tranny from B &amp; M will I have to worry about the modulator? I had a T-350 before.
    Chad
  11. Brian 89KBlazer
    779
    Ontario, Canada
    Chad
    I think you're OK from what I recall. Both the TH400 &amp; TH350 hook up the same way. Harry?? Ken?? Anyone else care to confirm?
    Brian
    89KBlazer
  12. HarryH3
    May 31, 2000
    10,384
    Georgetown, TX
    Yep, the modulator will already be installed in the tranny (just like on a Turbo 350) so just hook the vacuum line to it. [​IMG]
  13. californiak5
    californiak5 1/2 ton status
    Oct 25, 2000
    820
    Oceanside, Ca. 92056
    Is there a differance in length between the TH350 and the TH400?
    See Ya,
    Keith
    [​IMG] <font color=green>Born to Drive My K5</font color=green> [​IMG]
  14. Executioner
    Executioner 1/2 ton status
    Feb 22, 2000
    1,530
    Temp. Ft. Walton Beach Fl. home=Tucson, Az.
  15. californiak5
    Oct 25, 2000
    820
    Hey there Ex,
    I don't no what I would do without your help.[​IMG] I asked a straight forward question and got a straight forward answer.[​IMG]
    Now since I know there is a diferance in length between the two does anybody know what the doferance is? Thanks
    See Ya,
    Keith
  16. thebigdaddyof2
    thebigdaddyof2 1/2 ton status
    Dec 28, 2000
    2,053
    St. Louis, Missouri
    According to info I have from ORD:
    SM465 - 18 3/8"
    TH350 - 21 1/2"
    TH400 - 23"
    TH700R4 - 23 3/8"
    Hope this helps.
    thebigdaddyof2
