TH400 to a NP208
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by JunkYardCrawler, Nov 16, 2001.
  1. JunkYardCrawler
    JunkYardCrawler 1/2 ton status
    Sep 9, 2000
    575
    Tucson, AZ
    i was woundering if the TCI one in Summit would work to replace one on an 86 3/4 tone. thanx
  2. JunkYardCrawler
    Sep 9, 2000
    575
    Tucson, AZ
  3. K10ANDYKHAMNIC
    K10ANDYKHAMNIC 1/2 ton status
    Sep 17, 2001
    1,962
    Western CO
    i dont see y not ....
    dents ....
    O R D's axles
    NO BREAKAGE :)
  4. JunkYardCrawler
    Sep 9, 2000
    575
    Tucson, AZ
    summit say that the TH350 would go up but i think its the TH400 in it now. i not much of an auto tranny guy. so i not totaly sure.
  5. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    If the pan looks like a square with a corner cut off, it's a TH 350.
    If it looks like the state (Republic????) of Texas, it's a TH 400.
    Tim
  6. 95 Silverado
    95 Silverado 1/2 ton status
    Nov 9, 2001
    467
    Central PA
    4WD application transmissions have a different length output shaft, it isn't as long as the car trannies, be sure you get the correct one for your truck. also a 350 turbo has a 27 spline output, the 400 turbo has a 32, you will need the correct one to fit your transfer case.
