th400 to np241
Discussion in 'The Garage' started by Cole, Jul 25, 2006.
  1. Cole
    Cole Registered Member
    Jul 7, 2005
    13
    Kentucky
    i have a 1986 k20 silverado with the np208 t-case which needs to be rebuilt...i also have a np241 from a 1989 k5 is it possible to just swap out cases...will i need an adapter if so who makes them...im looking for the cheapest and easiest way to get the silverado up and running so i can get out on the trails.
    Thanks, Cole
  2. ryan22re
    ryan22re 1/2 ton status
    Feb 5, 2005
    3,368
    Irmo, SC
    Adapters are the same. Bolts right up.
  3. wayne
    wayne 3/4 ton status
    Feb 1, 2001
    6,178
    Carlisle, Pa
    You need a 32 spline input for your 241 if it came from a K5 with a 700r4 trans and you are putting it behind a th400. As mentioned it will bolt to your existing adapter.
  4. tavis
    tavis Registered Member
    Mar 13, 2004
    11
    Yes you either have to find a 32 spline input np241 from behind a 4l80e/NV4500 or replace the input shaft on the T-case (GM part#12547998)
    I am assuming that the current setup is TH400->np208. If you currently have the a 700r4->np208 you will have to move the crossmember forward ~1.5" to accomidate the shorter TH400.
    T.
  5. thatK30guy
    Jan 12, 2001
    32,076
    55
    Shouldn't have to move the crossmember at all.
  6. Cole
    Jul 7, 2005
    13
    Kentucky
    is it possible to swap the input shaft from the 208 to the 241...
  7. mikey_d05
    mikey_d05 1 ton status GMOTM Winner
    Nov 23, 2004
    10,453
    Minnesota
    I doubt it, but new inputs are easy enough to find. Make sure you get the bearing along with input. When I swapped my input for a 32 spliner the original bearing was too thick.
  8. wayne
    Feb 1, 2001
    6,178
    Carlisle, Pa
    No.
  9. wayne
    Feb 1, 2001
    6,178
    Carlisle, Pa
    When I did it I didn't need to swap any bearings. Do you have a part number for the bearing you used compared to the origional?
  10. mikey_d05
    Nov 23, 2004
    10,453
    Minnesota
    Nope, but I do know that my case was a passenger drop and the case I got the input from was a driver drop. My case is an '89 but I have no clue what year the other case was.
  11. wayne
    Feb 1, 2001
    6,178
    Carlisle, Pa
    That might be it. My inputs came from pass drop cases.
  12. hack500
    hack500 1/2 ton status
    Sep 16, 2005
    523
    Templeton, Ma
    another thing to keep in mind is that a 241 has a different overall-length than a 208.
  13. jp0863
    jp0863 1/2 ton status Premium Member
    Aug 15, 2004
    566
    clovis, ca
    i did it in mine, all i had to do is swap the input, very easy and it cost me about $30 from jb conversions. i also did the sye on mine too so i needed new driveshafts anyway. if i recall correctly the input is 6 bolts, but very easy to do. slap on some silicon and call it good. dont know much about whether or not the stock drive shafts would work, but they should.
