TH400 torque converter bolts??
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Sample, May 16, 2003.
  1. Sample
    Sample 1/2 ton status
    Oct 15, 2002
    536
    Apache Junction, AZ
    I pulled the 700R4 off the 350 to put in the 400. The TQ on the 700 had threaded mounting holes to bolt it to the flex plate, but the 400's holes aren't threaded. How do you mount the 400 TQ to the flexplate?
  2. nvrenuf
    Jan 7, 2002
    13,072
    245
    Mobile, Al.
    Some converters (usually performance applications) use nuts & bolts to secure it to the flywheel.
  3. Calclips
    Calclips 1/2 ton status
    Apr 4, 2001
    1,005
    Swartz Creek, Michigan/Flint while in school
    My th350 uses nuts and bolts... I'm not sure if they are a special nut and bolt or not, they look normal to me...
  4. 8_YOUR_H2
    8_YOUR_H2 1/2 ton status
    Feb 20, 2000
    2,663
    Iowa
    I made the 700R4 to TH350 swap and I just used a grade 5 bolt with a washer and lockwasher. I have not had any problems.
  5. BrianDamage
    BrianDamage 1/2 ton status
    May 14, 2001
    753
    Alabama
    I had the same problem with a t350 torque converter on my old el camino. the original had threaded holes and the one I got from Summit just had clearnace holes. They do make "special" nuts & bolts kits for this, but I had a hard time finding them. Finally got a set from Classic Industries. You can just buy nuts & bolts separately and make it work though.
  6. nvrenuf
    Jan 7, 2002
    13,072
    245
    Mobile, Al.
    Buy some FINE thread bolts and LOCK nuts. Check the size of the holes in the converter, most are 3/8" but performance stuff will step up to 7/16". **I think** they will need to be about 3/4" long but double check that length.
  7. Sample
    Oct 15, 2002
    536
    Apache Junction, AZ
    I did exactly what you just said. Just gotta bolt them on today.
  8. gravdigr
    gravdigr 1/2 ton status
    Apr 15, 2003
    1,129
    Tyrone, PA
  9. slimlynn1
    slimlynn1 1/2 ton status
    Apr 9, 2003
    336
    Hamden, CT
    When I got my Torco Converter It came with Nuts and bolts for my converter. On my old converter, the converter was tapped for the bolt. It could be either way depending on the converter.
  10. Sample
    Oct 15, 2002
    536
    Apache Junction, AZ
    When I bolted the TQ to the flexplate it pulled the converter off of the tranny about 1/4". Is there supposed to be a spacer bolted between the two since I am using nuts and bolts? I always thought the TQ was supposed to be flush against the tranny.
  11. TWISTEDJACK
    TWISTEDJACK 1/2 ton status GMOTM Winner
    Jul 24, 2002
    882
    Boise, ID
    No spacer is needed. There has to be a little play so the
    crank has a little "end play".
