Th400 Transmission Filter Question
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 78Blazer, Aug 5, 2002.
  1. 78Blazer
    78Blazer 1/2 ton status
    873
    Michigan
    I bought a used 400 transmission anyhow I am just getting to putting it in. When I dropped the pan to change the filter and the bolt to the filter was loose I took it out with my fingers. But my question is when I went to put it back in there is the bolt and a spacer. Well when I tighting it up the bolt gets tight but there is still room between the spacer and the trans so the filter moves up and down a bit. I am assuming this bolt that is in there is wrong and I need one that will tighten down so the filter cannot move? or is this the way it is suppose to be?
  2. 84K5BD
    84K5BD 1/2 ton status
    May 19, 2001
    302
    arlington, mass
    that is the way it is supposed to be, kinda loose
  3. thatK30guy
    Jan 12, 2001
    32,076
    55
    That's normal for the slight moving of the filter.
    Sounds like the tranny you got has the deep pan, which is evident from the spacer you were talking about.
  4. 78Blazer
    873
    Michigan
    Thanks guys!!
  5. reddog64
    reddog64 1/2 ton status
    Nov 9, 2000
    3,325
    Federal Way, Washington
    yeah mine (th400) was kinda loose...
